Any experience with this welder? - JeepForum.com
post #1 of 12 Old 07-17-2013, 11:16 AM Thread Starter
Mulvihill64
I may be in the market for a welder in the next week or so, either that or more mods for the jeep (havent decided which yet) if so, would this be a good welder to start with http://www.homedepot.com/p/Lincoln-E...3#.UebQp6weXWd
I need a 110v welder, and one that is preferably in that price range or cheaper.
Mulvihill64 is offline
post #2 of 12 Old 07-17-2013, 08:47 PM
rjbruzan
Save up a few more bucks and get the same one with gas. This unit is marginal at best for roll bars.
With gas its a good unit for sheetmetal and slightly thicker. Once again the gas will give nice welds with less experience.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 12 Old 07-17-2013, 10:27 PM
AtTheHelm
For $80 more get the Hobart Handler 140. It includes a Smith regulator plus a better machine imo.
AtTheHelm is offline
post #4 of 12 Old 07-18-2013, 06:37 AM Thread Starter
Mulvihill64
Ron
I read the one I'm looking at can be converted to gas, and is the gas one also 110v?
Instagram: Mulvihill64
post #5 of 12 Old 07-18-2013, 07:45 AM
rjbruzan
Yes to 120 volt and its cheaper to get the whole package at once.
Ron
rjbruzan is offline
post #6 of 12 Old 07-18-2013, 10:26 AM Thread Starter
Mulvihill64
ok i will probably go with the lincoln 140, just out of curiosity will this be powerful enough to outboard my rear shocks, or weld a truss onto my axle?
post #7 of 12 Old 07-18-2013, 11:40 AM
rjbruzan
Only if you are an experienced welder. This machine will be more than maxed out for those jobs. A 175 amp machine is the correct machine for those types of jobs.
Ron
rjbruzan is offline
post #8 of 12 Old 07-28-2013, 10:07 AM
RenoF250
That is too small for many projects, you can find those a craigslist all the time from people moving up. I found a Millermatic 211 with tank for $900. It have about 2 minutes of use on it. It has been one of my best purchases ever. After having it I think I would pay $2,200 for it if that is what they cost.
RenoF250 is offline
post #9 of 12 Old 07-28-2013, 10:23 AM
mattmont
Better price
That is good for sheet metal work and that is about it. We had one in our tool & die shop for onsite work. If that is all you need Harbor freight has a 90 amp one that you can pickup on sale for $100 that can use flux core or be converted to gas that actually works better than the Lincoln did. We added a better clamp to the ground and are able to do pretty good welds up to 3/16" thick on good clean steel. The clamp from factory has a very small contact area. for the money on a portable you really cant beat them. but I would recommend a 250 amp welder for all your cage or frame work.
mattmont is offline
post #10 of 12 Old 07-29-2013, 12:01 AM
jason280
It can be done with a quality 140a machine, but I would only feel comfortable if the machine was set up with .035" flux core wire and the machine was on a dedicated 20-30a circuit 120v circuit. You can absolutely do trusses and shock tabs with a 140a machine, but it requires the correct amount of prep, and preheat never hurts. Like its been mentioned, a 175a and up machine would be preferred, but a competent individual could do it with a 140.
jason280 is offline
post #11 of 12 Old 07-30-2013, 09:15 AM Thread Starter
Mulvihill64
I think i will put this off until tax return time. I have a 220v outlet for my pool filter, I just need to check the amperage on the breaker. I figure it would be fine to run a short extension cord >50 feet to the welder?
post #12 of 12 Old 07-31-2013, 01:33 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
For less money and it can be used with gas.
http://www.ebay.com/itm/Lincoln-K218...item19dae70029
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
