Another TJ 4 link - JeepForum.com
post #1 of 34 Old 01-31-2011, 01:51 AM Thread Starter
cgmrdc
1988 MJ Comanche
Another TJ 4 link... 3 link added!
Thought id put this in too since most of the other stuff ive done for my jeep is in here
been puttin this off for a long time but ive finally gotten sick of replacing RE stuff so decided id take the money itd cost for another rebuild and do this. Running all 7/8 ruff stuff heims, triangulated 4 link with 2" .25 was DOM.
to start heres kinda the rough out line of link placements, its changed since this screen shot but once its finished all re input the final numbers
start of the truss, made at work one day real quick, 3/8 x 3" plate
pulled the jeep in friday and cut the axle out
cleaned the frame, and then the 8.8 lost all its old brackets 200 bucks down the drain...
tacked the new truss on and threw it up under to check the clearance to the tub at full bump
took a wire hanger and used it to get the profile of the housing and then transferred that to some cardboard to get the actual shape.then traced it onto some 3/16 plate and cut it out
nick and herschel cleaning it up while i make the upper link tabs out of some 3/8
the result, nice and tight
welds for the truss
truss welded up and and cleaned
more sexy welds
completed truss
cgmrdc is offline
post #2 of 34 Old 01-31-2011, 01:55 AM Thread Starter
cgmrdc
1988 MJ Comanche
Heres the start of my frame mounts, theyll make more sense once they are welded to the frame and i add the supports...
so my ruff stuff heims still havnt showed up and ive run out of things to do without them in hand so for the sway bar link mounts i thought id get creative.
and last but not least Beer-a-myd!
like i said, hopefully the heims how up tomorrow and i can place the frame brackets and get them clearanced, drill all my holes and cut my links, ill keep this updated once more gets done. feel free to ask any questions
cgmrdc is offline
post #3 of 34 Old 01-31-2011, 06:13 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice work!! I'm gonna have to remember the coat hanger template thing.. looks like a real time-saver.
Drilling those 3/8" thick upper link mounts by hand..
BESRK is offline
post #4 of 34 Old 01-31-2011, 09:17 AM Thread Starter
cgmrdc
1988 MJ Comanche
Thanks! Def made for real clean install...
And yeah, by hand... been looking for a used drill press but havnt found any in my area. Thank god for step bits! And lots of cutting lube lol
cgmrdc is offline
post #5 of 34 Old 01-31-2011, 09:17 AM Thread Starter
cgmrdc
1988 MJ Comanche
cgmrdc is offline
post #6 of 34 Old 02-02-2011, 09:59 PM Thread Starter
cgmrdc
1988 MJ Comanche
its done!
heims finally showed up, but without the misalignment spacers so i drilled all the holes out to 5/8 and took a piece of 2" square tubing (measures just ever 2" wide) and also drilled a hole in it and bolted the tabs to it while i welded.
uppers
lowers
sway bar mounts and primer
here are the frame brackets, holes allow for 50% and 70% AS
in place
the issue...
bc im using the 2.5" box its hard to space things away from the frame and i thought i had enough room... but alas... time to start cutting more...
in the mean time (to keep all the guys helping me busy) we went ahead and mocked everything up with PVC so they could cut the links
so while i worked on the frame notches the links got cut and the 8.8 got painted
and then another issue... but i knew it was gonna be the case. bc i run 5" of uptravel on 2.5" of lift, sometimes things get in the way of each other. nd i wasnt about to compromise the geometry i wanted bc of a little sheetmetal
heres another clearance problem that i havnt taken care of yet, the lowers hit the frame with about 3/4 " of travel
cgmrdc is offline
post #7 of 34 Old 02-02-2011, 10:00 PM Thread Starter
cgmrdc
1988 MJ Comanche
so now the solutions... i took and cut into the frame 2" down and half way into the top of the frame. then along to corner and just folded it in. then the ends were filled... i also gusseted the upper mount
which apparently i dont have a good picture of...
and the hole in the floor. 12 ga rolled and formed around the corner of my welding table... my buddy nick has prolly 4 hrs in em... would be nice to have the proper tools...
nick welding
so before anyone say, the lower mounts are butt ugly... why not shape em? well bc they are the same height as my skid so...
so bc the cutting brake needs separate lines i decided to run the lines down the uppers. i went through BOXES and BOXES of brake lines till i found soft lines with female ends on both ends. if anyone wants the pns let me know. they were like 12 bucks a piece but they only had two in stock... and you need 4...
need to get some clamps and actually permanently attach it but zip ties work for now...
on its own weight for the first time in 4 days
and the snowy shakedown... yes doorless
where it contacts
cgmrdc is offline
post #8 of 34 Old 02-02-2011, 10:01 PM Thread Starter
cgmrdc
1988 MJ Comanche
WOOOT!!!
cgmrdc is offline
post #9 of 34 Old 02-04-2011, 08:00 AM
Tyler99TJ
How much better do you think this set up is over the factory 4 link and track bar? Did you think about stretching your wheelbase?
I was looking to 4 link the rear and I figured that I might as well stretch it at the same time. Then I have to move my gas tank, and lengthen my driveshaft and get new corners and move the coils, etc...
Tyler99TJ is offline
post #10 of 34 Old 02-04-2011, 01:17 PM Thread Starter
cgmrdc
1988 MJ Comanche
MUCH!!! with the 8.8 and my wheel base about an inch back from stock i had all sorts of gas tank-rear diff-trac bar interference. to fab a trac bar that would clear everything and still allow the amount of down travel i run it made more sense to me to build this set up. also my trac bar bracket hit the rear x member and has pinched my fuel line almost completely shut. its fine for some but the engineer/fab nut in me likes the idea of being able to control the ways my suspension performs and knowing why it acts the way it does helps in a lot of situations.
stretching is a lot of work and takes a fair bit of time. and not really needed with 36s. with as little lift as i run my break over angle would suck. and this being my dd (and only vehicle i own) i cant afford that kind of down time. and imo a rear stretch w/o a front stretch looks goofy.
cgmrdc is offline
post #11 of 34 Old 02-04-2011, 03:16 PM
MO2500
Really great work
That frame mount is very cool and gives me ideas for mine when the time comes.
Also, I never would have thought of the trick with the coat hanger but that's a pretty cool trick. I'll have to remember that
Instagram: @omsmike
MO2500 is offline
post #12 of 34 Old 02-06-2011, 11:30 PM
Jtrux
I dont know much about heim joints but do you think they will last with DD use?
Jtrux is offline
post #13 of 34 Old 02-07-2011, 03:56 PM Thread Starter
cgmrdc
1988 MJ Comanche
Dave at ruff stuff said I should be getting between 18 and 24 months out of em, depending on what kind of terrain I wheel on, which is more than I was getting between rebuilds on my re joints... but to further answer that, the ride is so much better than is was with re. Everything feels tighter and the rear end actually follows the jeep and not the road.
cgmrdc is offline
post #14 of 34 Old 02-07-2011, 05:02 PM
ytowntj
Nice work! I might be a bit partial to the steel blue
Im looking at doing something similar and outboarding as well. Compared to the Ruffstuff heims, how do you thing JJ would hold up?
ytowntj is offline
post #15 of 34 Old 02-07-2011, 07:08 PM Thread Starter
cgmrdc
1988 MJ Comanche
Call currie and talk to them is all I can really say. Johnny joints are pretty popular I just wanted to try these.
cgmrdc is offline
How to make a suspension link or steering link BlueTorch Fabrication Shop 7 09-03-2009 02:32 PM
3 link. 1977cj7 Tires & Wheels 0 03-22-2008 01:57 PM
3-Link vs. 4-Link djXternal Tires & Wheels 0 12-09-2006 11:12 PM
WA. 4 Link Fab Help 91jeepster Fabrication Shop 2 02-10-2006 12:20 PM
Looking for a link. Markie70 General Jeep & Off-Road Equipment 1 12-29-2005 06:56 PM
