Another off road trailer - JeepForum.com
post #1 of 63 Old 01-08-2015, 07:05 PM Thread Starter
Bobby6319
How do I upload pics?
Bobby6319 is offline
post #2 of 63 Old 01-10-2015, 08:05 AM Thread Starter
Bobby6319
Ok I think I figured it out
post #3 of 63 Old 01-10-2015, 08:07 AM Thread Starter
Bobby6319
Wheels and tires
post #4 of 63 Old 01-10-2015, 08:27 AM
Jim1611
Jim1611's Avatar
Looking good! A receiver hitch on the back might come in handy someday too. If I were going to put one back there I'd tie it to the crossmember that the hitch ends on. That way it's pulling from the ball and not the back crossmember.
Jim1611 is offline
post #5 of 63 Old 01-10-2015, 08:34 AM Thread Starter
Bobby6319
I am planning on it was going to run the tongue all the way back but not enough clearance between it and the axel . I want to drill the pin hole before I mount it and it will go to the second cross member just like the front
post #6 of 63 Old 01-10-2015, 12:21 PM
Jim1611
Jim1611's Avatar
Great. I'd still tie those crossmembers together in some way. You'd have room if you welded some tubing in between them. One reason I like the idea of the hitch on the back is I can't remember how many times I've needed to pull someone out or put a light pull on something but the trailer was in the way. With a receiver on the back end you could pull something, not a heavy pull but maybe enough to do the job. I love watching these trailer builds!
Jim1611 is offline
post #7 of 63 Old 01-20-2015, 09:30 PM
TXST8tj
TXST8tj's Avatar
What axle and springs?
What are the basic dimensions?
TXST8tj is offline
post #8 of 63 Old 01-22-2015, 04:22 PM Thread Starter
Bobby6319
It's a3500lb axel and springs with 46inch center to center.
post #9 of 63 Old 01-22-2015, 04:30 PM Thread Starter
Bobby6319
Update
Got the rear receiver mounted it is braced like the front but inside under the floor. I also got the reinforcement rings around both recievers
post #10 of 63 Old 01-22-2015, 04:32 PM Thread Starter
Bobby6319
Here's the front
post #11 of 63 Old 02-14-2015, 04:40 PM Thread Starter
Bobby6319
Well working on the fenders now
post #12 of 63 Old 02-14-2015, 04:43 PM Thread Starter
Bobby6319
Side view
post #13 of 63 Old 02-14-2015, 04:45 PM Thread Starter
Bobby6319
One more
post #14 of 63 Old 02-15-2015, 04:57 PM
Jim1611
Jim1611's Avatar
Those fenders should hold up very well.
Jim1611 is offline
post #15 of 63 Old 02-17-2015, 10:57 AM
83cj8
1983 CJ8
Fenders
Looks like you framed out your fenders and then bent a piece of plate to go over the framed out fenders. The angles of your plate so it is linned up with the framed out section is perfect. Did you shear the plate and make the plate bends in your garage or take it to a shop for that to happen?
Nice work. Are you going to fill the sides, front and bottom with plate? If so, what gauge or thickness?
karl
83cj8 is offline
