Another HF tool question - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Another HF tool question
Raceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-GearTJ Dana 60 - BOLT IN REAR
Unread 06-17-2008, 04:17 PM   #1
Fastbeeatch
I went to buy the 20lbs pressurized sandblaster from them it was on sale for $50, so I figured that was a good deal. Well they didn't have it in stock so they are going to call me when they have it. Now that the impulse shopping bug as faded i'm starting to wonder how well this works. I would only be using it on small areas of my frame where I couldn't get the grinder and misc smaller parts. Anybody using this product, are you happy with it, what kind of media are you using for rust/paint removal?
95 4L Auto D300 TC
103" Wheelbase
D60 Front 14 Bolt Rear 4.10 Gears
H1 Wheels 36" GoodYear OZ Tires
Fastbeeatch is offline   Reply With Quote
Unread 06-17-2008, 05:46 PM   #2
jgorm
I bought the $20 top loader version from HF. I picked up some Al medium media when i was there too. It works great and takes paint and rust off quick, but wear a respirator and goggles because there is a lot of bounce back and mess. I can't believe how much time a little POS HF sandblaster has saved me, shoulda bought it years ago. I really need a blast box to keep the media out of my face, and to reuse it, but it will only work with small parts. It will blast the size of a penny clean in about 1-2 seconds.
jgorm is offline   Reply With Quote
Unread 06-17-2008, 05:51 PM   #3
Fastbeeatch
Thanks that is what I was wanting to hear. Did you buy your media at HF or somewhere else.
95 4L Auto D300 TC
103" Wheelbase
Unread 06-17-2008, 06:01 PM   #4
jgorm
HF. I didn't plan on buying it, but i figured $20 + media is worth a shot. I blasted a bunch of rust and paint off my wheelbarrow to test it out, and was impressed on how clean it got the metal. Its a loud messy job, and i hate wearing my respirator. I figured "I'll just hold my breath" but then my nose smelled like metal for hours after so i figured thats probably not good. The stuff just flies every were. I use a orbital sander on all the flat pieces with easy access. The sandblaster is for the places i cant get with the sander. Sometimes i use a flap disk instead of a sander depending on what type of finish i want.
Unread 06-26-2008, 11:00 AM   #5
silvrjeepr
I'd been looking at the HF blasters for sometime when I came across this: http://www.pablaster.com/
I spent the $10 for the plans and built two of them. One from PVC, and the other from a water tank. So far I'm really happy with both of them. Just another option...
Originally Posted by mrblaine
No Lurch, why do you ask?
silvrjeepr is offline   Reply With Quote
Unread 06-26-2008, 03:23 PM   #6
Fastbeeatch
How much media does the pvc one hold, also what kind of nozzle and tip is used?
95 4L Auto D300 TC
103" Wheelbase
Unread 06-26-2008, 05:23 PM   #7
Bigbob
Bigbob's Avatar
Get it. I currently don't have one, but I used to have the top load, siphon type. Problem with the top load units I have had is, they get crap in the tub and the orfice gets plugged up. If you do get a top load just make sure you cover it when not in use. I don't think the pressure units have that problem. When you get the blaster also get a full face mask. I used an old 4" view welding helmet and removed the tinted glass. This worked very well. Get ear plugs both for the sound and you don't want sand in the ears. Long sleeve shirt, I always used welding sleeves and gloves. Get a good resperator. A good broom to sweep up and tarps to lay down also come in handy.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Unread 06-26-2008, 06:41 PM   #8
Fastbeeatch
I'm getting a little annoyed with HF it's been 2 weeks and they still don't have it in. I sanded all the areas I could on my frame now I need the blaster to finnish off the sections I couldn't get to. I'm really wanting to paint this frame and start rebuilding my jeep.
95 4L Auto D300 TC
103" Wheelbase
Unread 06-30-2008, 01:59 PM   #9
Bushytails2
A relative has the pressurized one, and it works quite well - it certainly is faster and clogs less than the siphon-feed variety - but it goes through sand like you wouldn't believe. Make sure you're using a capture&filter system, or it's expensive to run. You'll also need >15CFM to run it at a good duty cycle.
--Bushytails
Bushytails2 is offline   Reply With Quote
Unread 06-30-2008, 02:04 PM   #10
Fastbeeatch
I finnaly got mine in. It does work real good, and it sure does go thru a lot of sand 100lbs goes by in less then 1/2 hour. Also I did have to buy a bigger compressor this thing uses a lot of air. All in all a good product I am very pleased with it.
95 4L Auto D300 TC
103" Wheelbase
