Anchors away - JeepForum.com
post #1 of 12 Old 05-14-2013, 06:44 PM Thread Starter
lar308
Anchors away
I have a YJ I've done some modifications to. I threw together a bumper with 1" anchor points welded front and back.
I like the anchoring to the side of the frame using the 3/4" holes with grade 8 bolts. I have built a new bumper.
The side mounting plates are 1/4" thick.
So my question is how thick does the side plates need to be so they can be used as a recovery point when anchored to the frame as opposed to being welded and anchored with 6 bolts as with production bumpers.
Thanks for your time, I can answer questions as needed. Ron
lar308 is offline
post #2 of 12 Old 05-15-2013, 07:08 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Great looking bumper ! Looks very similar to the ORFab bumpers.
I've seen this a few times on different bumpers on the market, and while I've not built that design I would suggest something at a minimum of 3/8". Not even as much from a strength of pull force, but from a flex point of view. 99 percent of the time....your anchor pull is never 90 degrees perpendicular to the anchor point base. Because of this, the force (pull) will be applied from an angle not at the strongest plane.
Long story short, and why clevis mounts are so thick usually...is to handle the load without wallowing out the clevis hole or bending/flexing under load from an angle other than exactly 90 degrees to the bumper.
Tomb Raider is offline
post #3 of 12 Old 05-15-2013, 07:43 AM Thread Starter
lar308
Thanks for the reply. I was thinking 1/2 minimum maybe 3/4. I looked a lot of different bumpers, most were single tube mounted to a plate. They looked like an after thought as far as mountings and tow points. I need a lot more practice on notching tubing on a compound angle. Thanks again, Ron
lar308 is offline
post #4 of 12 Old 05-15-2013, 09:16 AM
Tomb Raider
Addicted...
I've seen a couple ARB bumpers that use this design(tow point also mounting plate) and theirs are at the 1/2 to 3/4 thickness.
post #5 of 12 Old 05-15-2013, 12:29 PM Thread Starter
lar308
Thanks again, I figured with the 6, 1/2" bolts and 4, 3/4" bolts, all grade 8, the weak point won't be the mount. Thanks, Ron
lar308 is offline
post #6 of 12 Old 10-18-2013, 12:46 PM
ldso
Never saw it mocked up, looks sweet! You did some nice work man.
I have wondered about that myself, how thick the clevis mounts should be for recovery.
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #7 of 12 Old 10-18-2013, 05:03 PM Thread Starter
lar308
I've tested the anchor points with small pulls, cherokees and such. Seems to be holding up well, I may increase the thickness on the next one. Ron
lar308 is offline
post #8 of 12 Old 10-19-2013, 01:09 PM
kjg26
kjg26's Avatar
Any pics of it mounted on the jeep:
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #9 of 12 Old 10-19-2013, 02:59 PM Thread Starter
lar308
Here's one, I'll get more, Ron
lar308 is offline
post #10 of 12 Old 10-21-2013, 11:05 AM
ldso
HAHA small pulls, little Cherokees
ldso is offline
post #11 of 12 Old 10-21-2013, 04:11 PM Thread Starter
lar308
Here's the other pic's.
lar308 is offline
post #12 of 12 Old 10-21-2013, 04:17 PM Thread Starter
lar308
lar308 is offline
