ammo can console/lock box - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > ammo can console/lock box
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-17-2012, 04:23 AM   #1
Motorcharge
SWANSON 2016
Motorcharge's Avatar
1992 XJ Cherokee
Just did one for my Dakota, but it's pretty universal so I figure someone might benefit from this thread.
5.56 ammo can - $16 at local military surplus store
4x white LEDs - $10 at Advance Auto
1x toggle switch - $5 at Lowe's
6x 1" #8 self tapping screws - $1 at Lowe's
1x mailbox lock - $5 at Lowe's
total: $37
other supplies I had lying around:
Flat black spray paint
16ga wire
tools needed:
drill
drill bits
wire strippers
grinder (if you want to remove the handle on top and the front so that they don't rattle)
cutting blades
The lock, LEDs and toggle switch are all that will be going on it for now. Sometime in the future, possibly next weekend I'll be adding a second toggle switch and exterior LED's on either side as long as strips under the dash for footwell lighting when needed.
5.56 Ammo Can
hole layout for toggle switch on drivers side
LEDs, toggle switch, and lock
hole layout in rear for LEDs
test fit for LEDs
holes layed out and drilled for where I'm mounting it
Project Motörcharge | XJ Non-Tech FAQ | Ammo Can Lock Box | Rear Bumper Build | Front Bumper Build | Pre-95 GC-XJ Seat Swap | Motorcycle Build
Under my tutelage, you will grow from boys to men. From men into gladiators. And from gladiators into Swansons.
WANTED: Decent condition MJ tailgate - PM for details.
If you find my post to be good or helpful please take a second to click the "thumbs up" icon near the quote option. Thank you.
Motorcharge is offline   Reply With Quote
Unread 04-17-2012, 04:24 AM   #2
Motorcharge
SWANSON 2016
1992 XJ Cherokee
Finished it by welding a small piece of steel onto the side on the inside for the latch on the lock to catch. Forgot to take a picture of that, but got everything else.
Removed the front handle. You could use a grinder, but I just hit it with bolt cutters.
Did the same thing with the top handle. The top hole I cut out for the lock.
Cut the hole for the switch next.
Lock and switch test fits.
Once everything was all fit in place I threw some semi-flat black paint on it.
Unread 04-17-2012, 04:26 AM   #3
Motorcharge
SWANSON 2016
1992 XJ Cherokee
I didn't take pictures of the wiring process for a couple reasons. One, it frustrates me enough doing electrical work without stopping to take pictures, and two not everyone will wire it the same. I tied mine into the 12v constant for the cigar lighter. I just pulled the dash cover, radio, and stereo. Wired the positive into the 12v constant and the ground wire to the ground strip for the radio. Ran both lines down through the openings in the dash and down behind the ashtray molding where they dropped out the bottom.
As for mounting it to the floor, I simply ran a pencil on the pre-drilled holes in the box, then drilled pilot holes in the trans tunnel, there's plenty of space without hitting anything. Then I put washers inside and ran 1" #8 self tapping screws down and it's plenty sturdy.
Anyway, here's final pictures.
Unfortunately one of the 4 LEDs was broken out of the package. I'll end up replacing it later.
Unread 06-23-2012, 10:45 PM   #4
Texsun
Texsun's Avatar
Awesome! Stealing idea!
Texsun is offline   Reply With Quote
Unread 08-20-2012, 05:42 PM   #5
MachinistMade
1992 XJ Cherokee
nice man! Cheap too, especially because i already have a couple of these ammo boxes lying around collecting dust. i like the integrated LED's.
MachinistMade is offline   Reply With Quote
Unread 08-21-2012, 05:42 AM   #6
fitzp20102
1983 CJ7
Love it... Good pictures. Thanks...
Glenn Fitzpatrick
Facebook.com/zoesoffroad
[email]ZoesOffRoad@me.com[/email]
(301) 960-5125
Now dealing with ROUGH COUNTRY SUSPENSIONS and YUKON AXLE & GEAR!
The best Teraflex deals on the East Coast! From Teralow gear sets to 6" LCG kits with Fox Racing Shocks and all lift kits in between. Inquire Within! A new business with fantastic introductory prices!
fitzp20102 is offline   Reply With Quote
Unread 08-21-2012, 11:54 PM   #7
Cutlass327
Cutlass327's Avatar
1978 CJ5
Good idea, but I'd have hid the switch in the hinge side - less chance of bumping.. and what is the lock supposed to latch to? I think I'd have tried to incorporate it into the big hole in the handle - if you cannot lift the handle, you cannot open it..
Just random thoughts, but like I said, good idea!
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote
Unread 08-22-2012, 04:21 PM   #8
Motorcharge
SWANSON 2016
1992 XJ Cherokee
When I did this originally it was on the trans hump in my Dakota. Plenty far enough from my leg and in a good spot to flip it on if I needed to grab something real quick.
I welded a piece of 1/8" plate to the inside wall (no pics of it, sorry) for the latch to catch on.
I'd be comfortable storing most anything I own short of a firearm in it, but realistically if someone really wants to get into it they're going to find a way.
