Ammo box as center console... - JeepForum.com
post #1 of 7 Old 04-23-2010, 10:07 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Who has this setup?
planning it out in my head, im trying to figure out how to secure it to the tub. I think i could drill through the box and the tub and secure it with a nut/bolt.
Also, how do you make room for the emergency brake? does it need to be cut to accomodate the brake lever?
Any pictures of links to other threads showing the process would be appreciated.
-Dave
AustinCJer is offline
post #2 of 7 Old 04-23-2010, 10:16 AM
tjsahara1979
I ended up drilling through the tub and bolting it down that way. For the e-brake you do need to cut out a portion of the bottom and front. At the time I only had a dremel. It took a while, but it worked! This is the only picture I can find right now. If I find more, I'll let you know.
Originally Posted by Dave Barry
There is a very fine line between "hobby" and "mental illness"
'01 TJ Sahara. 3" BDS lift, 1" PA BL, 33x12.50x15 Nokian Vatiiva M/Ts, Durango steering box, soft 8s, RE steering stabilizer, and one LOUD effin' train horn :)
Green Jeep Club Member #183
tjsahara1979 is offline
post #3 of 7 Old 04-23-2010, 10:33 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Thats a perfect example... How does it sit different from the factory console? is it lower? How comfortable is it to rest your arm on while driving? Does it lock and stay securely closed?
Thanks again!
-Dave
post #4 of 7 Old 04-23-2010, 12:04 PM
ZSXJ430
2015 KL Cherokee
I can not imagine that it is very comfortable...cold steel is not friendly on an elbow.
But, it does look cool.
'15 Trailhawk - Eco Green, V6, Nav, Tow, Cold Weather. Wrangler All-Terrain ProGrades 245/70R17.
ZSXJ430 is offline
post #5 of 7 Old 04-24-2010, 07:22 PM
hpycmpr
i have it also. in the shop right now so cant take any pictures. its very comfortable and it is weatherproof. doesnt lock unless you put in something on the handle. i will take a bunch of pictures for you when i get my jeep back next week.
hpycmpr is offline
post #6 of 7 Old 04-25-2010, 10:47 AM
tjsahara1979
Thanks again!
It sits about 1/2" higher than the stock console did. It's actually surprisingly comfortable to rest my arm on. It's not really cold or hot. To lock it, I drilled two holes in the front and back inside the latch. Then I painted and bolted on two ubolts so I could secure it with pad locks. I did have to shave a portion of the rear lip on the top so it would open all the way. You'll know exactly what I'm talkin about once you open it on one side.
Good luck!
post #7 of 7 Old 08-16-2013, 12:17 AM
ZSXJ430
2015 KL Cherokee
Did anyone ever take more pictures?
ZSXJ430 is offline
TJ: Ammo Can Center Console wilburburns Fabrication Shop 19 12-07-2010 09:31 PM
DIY Center Console RocknRubi Fabrication Shop 40 03-21-2010 03:08 PM
center console sub to non-subwoofer console? glook Audio, CB & Ham Radios, GPS, & Electrical 3 11-19-2009 02:37 PM
Center Console shunt Fabrication Shop 16 12-09-2008 10:17 AM
Center console q's 91yjeeper Audio, CB & Ham Radios, GPS, & Electrical 3 07-10-2004 09:52 AM
