Aluminum Armor - JeepForum.com
post #1 of 17 Old 11-19-2013, 12:32 PM Thread Starter
grandboost98
Aluminum Armor
I have a chance to put my Jeep on a diet by having a friend make me some rockers and bumpers in 6061 1/4" thick aluminum. The rockers will be easy, theyre going to be 5"x3". He seemed skeptical that an aluminum bumper would hold up to a lot of tugging though but hes used to full size lifted fords on 40s...
After looking at some designs from other companies it seems as though some use a steel sub structure or are all aluminum but have bolt on steel shackles mounts and other accessories rather than welded.
Can anyone tell me exactly how I should have him build them? Is TIG welding the shackle tabs on bad? And would I be able to mount a winch directly to an aluminum front bumper or would I still have to run a mounting plate?
TIA!
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #2 of 17 Old 11-19-2013, 11:08 PM
Shadownwpa
I wouldn't bother with aluminum, just my opinion but I'd want something more stout and easy to work with. Also... unlike metals corrode each other, beware.
Shadownwpa is offline
post #3 of 17 Old 11-19-2013, 11:44 PM
Imped
Imped's Avatar
1/4" 6061 will be more than adequate for both of those applications.
Yes, you can mount a winch directly to it, yes you can TIG weld shackle tabs (not sure why you think that would be "bad"), and yes you can tug on all of the big trucks on 40s you want to.
This is assuming the recovery points are where they should be and a little thought is put into the bumper design.
OlllllllO
IndyORV
Imped is offline
post #4 of 17 Old 11-20-2013, 05:58 AM Thread Starter
grandboost98
I plan to keep steel for skids underneath but I think aluminum will be fine on top and help the 4 banger move around better. But thanks for the heads up on corrosion, Ill have to look into that more as well
Thank you for your input. I see you have aluminum armor and its good to hear from someone with personal experience.
I was doing some research and, while Im no expert on the subject, I read that welding 6061 will weaken it to the strength of 5052. Not sure how detrimental that really is though. I assume thats why most aluminum bumpers are mainly bent with only the end caps being welded. And why I only saw a couple that had the shackle tabs welded on.
I assume the recovery points would be located closest to the mounting location and should be welded front and back or I guess bolted as other companies seem to do.
I took off my current rear bumper last night for him to use as an idea and measure out all the mounting locations. Ill be dropping it off to him today after work so if you or anyone else could explain any details that I could tell him to improve the design, that would be great!
Thanks again!
post #5 of 17 Old 11-20-2013, 12:09 PM
rchase559
I'm assuming that you are planning in using 6061 T6. While it can be welded, the strength of the material around the weld will be significantly decreased (from what I remember, it is around a 70% - 80% decrease). You can have it heat treated to bring it back up however.
I wouldn't use then as recovery points without having them heat treated after welding.
rchase559 is offline
post #6 of 17 Old 11-20-2013, 12:25 PM Thread Starter
grandboost98
Correct, he would be using 1/4" 6061. I did read somewhere that welding decreases the strength down to 5052 but that didnt mean too much to me. 70-80% does and thats a big difference
I wouldn't use them as recovery points without having them heat treated after welding.
Knowing that now, I will look into bolt on shackle tabs and only have the end caps welded on. Im not sure but I dont think they do any heat treating there. I could be wrong though
post #7 of 17 Old 11-20-2013, 12:45 PM
rchase559
Originally Posted by grandboost98
Correct, he would be using 1/4" 6061. I did read somewhere that welding decreases the strength down to 5052 but that didnt mean too much to me. 70-80% does and thats a big difference Knowing that now, I will look into bolt on shackle tabs and only have the end caps welded on. Im not sure but I dont think they do any heat treating there. I could be wrong though
You don just buy 6061. There is another designation after it (T0, T4, T6, etc) that signifies it's temper. Some companies will do custom tempers but that is typically not something you'd get when ordering from your local metal supplier.
5052 is the same way. There is a temper associated with it.
These tempers will affect the materials properties including the yield strength and ultimate tensile strength. One cannot simply compare the strengths of 6061 to 5052 without knowing what the temper of each is.
Just some food for thought.
post #8 of 17 Old 11-20-2013, 01:06 PM Thread Starter
grandboost98
Like I said earlier, Im no expert on the subject, so thank you for explaining more to me. My area of expertise is electrical. Ive only done a little research over the past couple days on the subject and have not went in that deep yet. I did not ask what T rating they use there but I will ask today when I drop off my bumper
post #9 of 17 Old 12-18-2013, 12:57 PM
84jeepcj7rock
I have some GenRight corner blanks made from 6061. Not sure which temper. After cutting the wheel opening out, I wanted to make a transmission tunnel out of the left over. I couldn't bend it. Took it to a shop with a 20 ton press and could only flex it. No concern about strength. Mine was only 3/16
84jeepcj7rock is offline
post #10 of 17 Old 12-18-2013, 01:22 PM Thread Starter
grandboost98
Wow, thats good to hear. Although the strength issue only comes up after being welded, without proper heat treatment
Its still in the fab shop. Ill be sure to update the thread when I get it!
post #11 of 17 Old 12-18-2013, 10:55 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
The 3/8th inch thick AL bumpers on my truck I ran out in the oil patch had cut outs around the recovery points (which were made out of steel)for heavy pulls and the recovery points were tied into the frame. Of course you are talking about a truck that weighed in at a hair under 200,000# though. Every ounce counts!
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #12 of 17 Old 02-13-2014, 07:17 AM Thread Starter
grandboost98
Well I picked up my old bumper and had a talk with him. He told me he tried a few times to bend a 90* for the rockers but whenever he came close, the aluminum would crack. He said he took down all the measurements he needs incase they get some different material to use but for now it looks like a bust
post #13 of 17 Old 02-13-2014, 04:09 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I know for pounding out a gas tank (for a motorcycle), you anneal the aluminum with a sooty torch flame to remove the heat treat. You then work the metal to the shape you want. When it's all said and done, you should be able to have it re-heat treated to strengthen it.
Probably need to do something similar for bending the sliders... or bend them with a really big radius.
BESRK is offline
post #14 of 17 Old 02-13-2014, 06:04 PM
danielbuck
1946 CJ2
Might be easier to start with an Aluminum L angle?
danielbuck is offline
post #15 of 17 Old 02-13-2014, 11:30 PM
jaspepp
6061-t6, when happens to be the most common temper of this grade, does not like to bend because of that temper. It will crack every time like that. If your forming it I would go go straight to 5052 which won't be tempered. The strength will have to come from the design.
"Idaho sucks!!!! Tell California"
jaspepp is offline
