air compressor pumps - JeepForum.com
post #1 of 6 Old 11-12-2008, 11:50 PM Thread Starter
JeepMKcomin
So the air compressor pump on my air compressor just died. I have been looking at different pumps to replace it with. My question is, what is the downside (or is there one) of using a pump manufactured for a 5hp motor on my 3hp motor? vice versa?
Also I am looking into plasma cutters soon... what kind of filter, water/oil separater, etc do I need to look into and where can I find a good filter rated for 120psi?
Thanks ahead of time.
06TJ Silver Ruby - REBB w/DT3000s, Quick Discos, Superwinch EPi9.0, Warn engine skid, PS Box Skid, Diff Guards, IPF Lenses, x51s soon
92YJ White - Slight Shackle Lift w/30x9.5 BFG ATs, Custom Beefy Bumpers
06TJ Khaki Sport - Traded in
JeepMKcomin is offline
post #2 of 6 Old 11-15-2008, 12:22 PM Thread Starter
JeepMKcomin
bump to the top...
post #3 of 6 Old 11-15-2008, 02:35 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I would imagine the 5hp pump is slightly bigger and therefore requires a little more power. Might work the 3hp motor too hard?
BESRK is offline
post #4 of 6 Old 11-17-2008, 09:56 AM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
I agree with BESRK that this isn't a good idea but my reasoning is this; powering a 5hp pump with a 3hp motor will not give you the output that's listed for the 5hp pump - and I'm not entirely sure it will even give you what you have now because you're underpowering a larger pump.
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #5 of 6 Old 11-22-2008, 12:38 PM
my-jeep-earl
1971 CJ5
Best to buy the filter at the same time as you buy the plasma cutter. Most manufactures recomend their own, ask your sales person. Get a good one because if any moisture gets into the machine, your warranty is void.
I'm buying myself a Hypertherm 45 for Christmas and springing $130. extra for their filter.
my-jeep-earl is offline
post #6 of 6 Old 11-23-2008, 05:36 PM
Fastbeeatch
Run an inline desicant filter directly at the intake of the plasma cutter, you can buy some that can be taken apart and dried in the oven or you can buy the cheap ones and swap them out when the little balls change colors.
95 4L Auto D300 TC
103" Wheelbase
D60 Front 14 Bolt Rear 4.10 Gears
H1 Wheels 36" GoodYear OZ Tires
Fastbeeatch is offline
Golden chance to get NOS ford gpw/willys oil pumps vintagecollecto Engines & Drivetrain 0 08-24-2009 01:20 AM
Two different oil pumps for 4.2L 258? tksnyder Engines & Drivetrain 0 04-13-2009 10:15 AM
fuel pumps jeepwrnglr92 Engines & Drivetrain 1 08-05-2008 09:34 AM
Airing Down & Air Pumps Syd V General Jeep & Off-Road Equipment 25 06-12-2007 12:10 AM
Using ARB compressor erickpl General Jeep & Off-Road Equipment 26 02-03-2006 12:26 PM
