Advise Trimming Rear fender Tub - JeepForum.com
post #1 of 9 Old 08-18-2013, 06:53 PM Thread Starter
Trendsetter75
2010 JK Wrangler
Okay Im doing a LCOG setup and Im going to run 35's and want to cut the existing rear fender flare holes in the tub so I need to cut about 2". I currently have the stock rear flares on now which I will draw an outline on top of the stock flares with wax pencil, then remove stock flares and cut. I want to know what would be the best and cleanest cut tool I would use to make a perfect clean cut on my rear tub.
2010 JKU (6-spd)
Trendsetter75 is offline
post #2 of 9 Old 08-22-2013, 03:15 PM
wushaw
Rockin jeep
wushaw's Avatar
I used plasma and a drum sander when I cut mine.
wushaw is offline
post #3 of 9 Old 08-22-2013, 06:24 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
I used a saber/jig saw with mine, put tape where you are going to cut to keep from chipping the paint/body filler (factory new jeeps have had lots of body filler on them in random places).
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #4 of 9 Old 08-22-2013, 09:47 PM
rchase559
I hope you check out where the welds that hold the fender well to the tub are before you start cutting. From what I remember when I trimmed mine, the spot welds weren't all that far away from the top of the wheel opening and 2" would have easily blown through a few of them.
rchase559 is offline
post #5 of 9 Old 08-25-2013, 12:32 PM
schitzangiggles
King of Macastan
When I did mine I found how high the seam I could go and stretched the rear about 3 inches. I stretched the wheelbase # 5 inches. I reused my stock flares and I pulled them to fit the opening. I don't think that you can do the with the hard OEM ones of the later years. The TJ/LJ you won't have ability to stretch as easily as I did, but you will have to get enough cut and bump stopped properly to keep the tires out of the sheet metal. You will loose up travel, but you will gain the ability to sidehill and cross obstacles that would roll you over otherwise, as a buddy of mine found out following me across a rock face.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #6 of 9 Old 08-25-2013, 04:16 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I usually use a plasma cutter and leave enough material to clean up with a flap disk.
I've also had good results with an angle grinder and cutoff disk. Same procedure.. cut a little fat, and clean up with a flap disk.
BESRK is offline
post #7 of 9 Old 09-04-2013, 06:30 PM
AstroZombie
Don't forget your charcoal canister is in the right rear of the tub inside the wheel well. Unless you relocate that annoying piece of junk it will limit how much you can cut.
2004 Black Rubicon. Locker mod and a few other things...
USN Jeep Club Hull # 199
AstroZombie is offline
post #8 of 9 Old 09-09-2013, 09:30 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
I have a little body saw. It's really quiet and zips through sheet metal like butter.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #9 of 9 Old 09-13-2013, 03:47 AM
oldcelicaracer
You can cut up higher u will just have to weld the two parts back together,remember to prim and paint when our done so it don't rust,like my whole jeep has done,(still making floor patch panels)
Sent from my DROID4 using JeepForum
oldcelicaracer is offline
