83 CJ7 spring under/over swap - JeepForum.com
post #1 of 4 Old 02-11-2011, 06:09 PM Thread Starter
83cjseven
1983 CJ7
I have a 83cj7, the axles are currently located over the leaf springs, I was wondering if anyone has relocated the axles to under the leafs for more tire clearance and a small inexpensive lift? Only real issue I see with this is making an adapter for the steering knuckles.
Opinions please.
83cjseven is offline
post #2 of 4 Old 02-11-2011, 06:55 PM
rdsk8ter
1982 CJ7
there are alot of topics on this
http://www.jeepforum.com/forum/f8/je...ersion-627649/
do a search youll pull up hundreds
rdsk8ter is offline
post #3 of 4 Old 02-11-2011, 11:18 PM
JohndKc
1987 YJ Wrangler
My wallet would beg to differ with Spring Over Axle being inexpensive. A high steet kit, most likely an sye, axle wrap bar, cv driveshaft. You can do a SOA on the cheap, but you will run into little problems down the line. I have to redo mine from the previous owner doing it incorrectly.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #4 of 4 Old 02-15-2011, 09:53 PM
KMD
1976 CJ7
Going to cost you at least $1200 to do an soa lift closer to $2500 if you can not fab your own parts.
KMD is offline
CJ front spring hanger swap. dmcfla Tires & Wheels 0 08-13-2008 01:28 PM
RE spring swap question 2000TJDude Tires & Wheels 1 12-15-2007 11:15 PM
Spring Swap vs BB w8l3 Tires & Wheels 5 01-15-2005 01:44 PM
coil spring swap pics 79cj360 Tires & Wheels 0 04-01-2004 07:46 PM
waggy spring swap on a yj RichHeezee Tires & Wheels 2 09-06-2002 11:23 AM
