8.8 build, weld brackets before or after regearing and new bearings? - JeepForum.com
post #1 of 8 Old 02-06-2011, 03:28 PM Thread Starter
linexrandy
My brackets came in and I was contemplating burning them on this week, but I also found a shop to regear it for $150 (I supply gears and install kit). Should I regear it after I weld the brackets on to prevent any possible damage to new bearings, or should it be welded first, then regeared. Just asking because I've always heard that the welding current will travel through the bearings and could possibley melt any rubber seals in the axle, and I will be moving soon and don't know if I can find any shops to do the regear for that cheap where ever I move.
Originally Posted by lumpster View Post
inca gold looks like yellow raped burnt orange and burnt orange decided to keep the baby. gross.
2002 TJ Apex edition. 3" Full Traction Suspension lift. 1-1/4" body lift, 1" mml. 33 X 12.50 - 15 BFG MT. 15x8 Soft 8's. LP30 and D44 rear. 8.8 and HP 30 disco for sale.
linexrandy is offline
post #2 of 8 Old 02-06-2011, 03:33 PM
Krochus
You're not going to do something stupid like attach your ground to the bearings or axle flanges are you?? If the answer is no then weld away
The person that told you this.....never listem to them again on anything either welding or automotive related.
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #3 of 8 Old 02-06-2011, 03:46 PM Thread Starter
linexrandy
Thats what I needed to know. Err on the side of common sense.
post #4 of 8 Old 02-06-2011, 04:19 PM
99TJSahara
Welding through the axle can cause arc spots on the bearings, so ground as close as possible and don't ground across the pumpkin.
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #5 of 8 Old 02-06-2011, 04:35 PM Thread Starter
linexrandy
This is what I kinda heard, the "pitting" for lack of a better word from the arc going through the bearings with the rollers as contact points. Of course, this is info I gathered from people who "heard it from a friend", not ones that actually had it happen to them.
Soon as I get my SYE installed, gonna mock up the axle, weld the brackets, then do the regear. That way I have nothing to worry about. Going to replace all bearings and seals anyways so it shouldn't matter. Come on tax return money!!!
post #6 of 8 Old 02-06-2011, 05:05 PM
Ironworker709
Ironworker709's Avatar
On a YJ most people have the axle all together and U-bolted into place so they can get the correct angle needed for the driveshaft while they have the vehicle load on the springs..THEN weld the bracket in place.
There is NO WORRIES about welding bearings together when welding the brackets on as long as you keep the ground close to your work and no bearings in the path of the weld current.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #7 of 8 Old 02-06-2011, 06:09 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The problems occur when you do something like.. attach your ground clamp to an axle flange, the pinion yoke or the carrier. If you did that, the full current would pass thru roller bearings and could cause arc pitting. If you attach your ground clamp to the axle housing/tubes/end flanges, you won't have any issues.
If time allows, I'd probably weld the brackets on first just so I wouldn't have to worry about the burning the axle seals.. or maybe having spatter find it's way into the carrier area somehow.. Other than that, it really doesn't make a difference which you do first.. weld or regear.
BESRK is offline
post #8 of 8 Old 02-06-2011, 06:38 PM Thread Starter
linexrandy
Dang, so there is some truth to it.
Weld-a-nut dz1087 General Jeep & Off-Road Equipment 1 03-01-2009 07:06 AM
How to Weld OffroadAlex Fabrication Shop 9 10-06-2008 08:14 PM
Weld On Brackets to attach sheet metal martells2 Fabrication Shop 4 12-09-2006 03:34 PM
Stick weld or MIG weld? theboxman71 Fabrication Shop 39 10-05-2006 06:46 PM
Which way to weld axle brackets? Testykalz Fabrication Shop 6 06-23-2005 12:30 PM
