8.8 anti-wrap bar idea, opinions? - JeepForum.com
post #1 of 1 Old 05-19-2010, 08:35 AM Thread Starter
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
When you have a CV shaft, an 8.8, and are SOA, the nose of the case is about the same height as the top of the diff cover. There is also a very thick nose vane on an 8.8 with holes in it (for a shock based anti-wrap as I recall). I have always preferred a right side anti-wrap because of the way the power forces work, so I came up with this idea.
Rather than the normal 'weld a vertical bracket to the tube and use a triangle bar' setup, I was thinking of using a straight bar/beam and a bolt on setup. A back bushing would be held in position by a robust diff guard, and a more forward bushing held in place bolted to that diff case vane and those holes. The far front would be a typical shackle style attach. A mini-mod to my exhaust would allow the room needed on the right side of the drive shaft. Any opinions on this working or not?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
Home brew anti-wrap bar Q JeeperDon General Jeep & Off-Road Equipment 21 09-13-2007 09:27 PM
Anti-wrap bar KC2OTE Fabrication Shop 7 02-09-2006 08:26 PM
Decided 1st welding fab job will be a anti-wrap bar. JeeperDon Fabrication Shop 12 09-17-2005 05:40 AM
Great Anti-Wrap Bar home built How To scottahicks Tires & Wheels 4 02-14-2003 09:31 AM
Serious anti-wrap bar! OldJeepguy General Jeep & Off-Road Equipment 3 01-18-2003 11:11 PM
