79 J-10 Custom Hitch Advice - JeepForum.com
post #1 of 4 Old 01-09-2014, 02:06 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I've been thinking about a rear hitch, especially since I've recently taken a couple loads of wood to my Grandpa. Pulling a trailer would allow for quite a bit more wood per trip. Plus, I need a hitch/recovery point. I looked at BJ's Offroad but they only sell receivers for the Wagoneer, Grand Wagoneer, and Cherokee. I know that the J-10 frame is wider than the Wag frame so clearly, that hitch won't work.
So, since a hitch cannot be purchased, I'm thinking about buying the steel and building one myself. I have two small welders (stick and wire), I have access to a shop with a plasma cutter and a nice welder, I may have access to an actual metal shop, and I have a friend who can cut me stuff on a CNC machine if I so need. In the tool department, I'm pretty much covered. If I go this route, what material do I need (size, type, etc.). I need to look things over but I'm thinking about building one for the front as well while I'm at it.
Any advice would be greatly appreciated. I'm not extremely well versed in this yet but with the friends and resources at hand, I feel confident in how this could turn out.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #2 of 4 Old 01-09-2014, 08:14 PM
AtTheHelm
Thought about just doing a rear bumper and integrating a receiver?
If your only doing a receiver then 3x3x0.25" should be fine.
AtTheHelm is offline
post #3 of 4 Old 01-09-2014, 08:27 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I'm just doing a receiver. The current bumper(s) will stay. I guess material sizes is more what I'm concerned about, which I know whether front or rear, will be the same.
Thanks for the advice as well!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4 of 4 Old 01-24-2014, 08:46 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Bump? I haven't started the project yet so any additional advice is welcome! I recently found out the friend with access to a CNC machine also has a stock pile of metal that 'needs thrown out'. I just need to let him know what size I'll need for everything (thickness, tube size, etc.). Thanks for the input so far AtTheHelm!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
