60 Amp Breaker for Stick Welder - JeepForum.com
post #1 of 4 Old 03-18-2011, 08:20 AM Thread Starter
krazymatt
This may be a stupid question, but the only stupid question is the one never asked I say!
I plan on running a plug in my garage for a stick welder. I have a 100 amp service box for the garage. I was going to run a 50 amp dual pole breaker for the welder. I remembered I used to have a hot tub so I currently have a 60 amp dual pole breaker not being used. Would I be okay running the 60 amp breaker instead of a 50 amp? Better a little too much than too little right? This makes everything easier and cheaper. I'll also use the wire I had for the hot tub plug. I'll just need to pull it from the conduit. If this all works all I have to buy is an outlet and box.
krazymatt is offline
post #2 of 4 Old 03-18-2011, 08:44 AM
Jim1611
Jim1611's Avatar
That'll work fine as long as the wire you use will handle 60 amps.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 4 Old 03-18-2011, 08:56 AM Thread Starter
krazymatt
It will. It was placed there by a certified electrician to run power to a hot tub via the 60 amp breaker.
post #4 of 4 Old 03-18-2011, 11:38 AM
Jim1611
Jim1611's Avatar
You should be good to go then.
My build thread
Jim1611 is offline
Anybody use a TIG/Stick welder for Stick? YJhobby Fabrication Shop 10 10-01-2010 09:36 PM
stick/tig welder bamacpl Fabrication Shop 6 01-28-2009 01:14 PM
Help with breaker for Welder Stan99 Fabrication Shop 11 08-18-2008 09:31 PM
What size breaker for 220v Welder RedMountainYJ Fabrication Shop 5 01-25-2008 05:39 PM
Hobart Stick Welder Bigbob Fabrication Shop 6 05-17-2007 11:55 AM
