5.0 ho tj engine conversion - JeepForum.com
post #1 of 54 Old 07-30-2002, 12:10 PM Thread Starter
drtjmpr17
drtjmpr17's Avatar
I have had a couple of requests for prices and time length... so here is everything that i had to do.......
( also the 5.0 is an efi engine .... the 5.0 HO is a full roller version of the 5.0 efi... minus the rocker arms.)
First I found a complete 5.0 ho at a junk yard out of a lincoln mark 7....
then I got a ford 302 bellhousing and an adapter for the ax15 transmission...
I should have bought a painless wiring kit but I am stubborn and did it myslef
Tore down my jeep now
pulled the whole front nose clip and engine...
put the adaptor on the tranny...
and then the bellhousing.
hammered all the seams in the engine compartment so that the engine would fit.
I used a ford 3 prong pressure plate and my jeeps clutch disc -- use a chevy 11 inch disc.
I also put on a 2.5 inch body lift to help this
bolted the bellhousing to the engine and layed it where I wanted it to sit...
Made the motor mount brackets myself....... straight off of the upper control arm brackets..... just a straight piece of metal to and a flat piece of metal... easy to fabb
sat the engine in and then the hard part...........
...............wiring.................
2 weeks figuring this out..........
total of like 10 wires to connect................ stupid me.....
then exhaust was crazy,,, drivers side is over the tranny.... thanks to the body lift..... to a 3 inch exhaust and a meanstreak muffler.
slave cylinder I made my own bracket, and used a chevy 4.3 slave cylinder.....
I also used the stock radiator .... works just fine.... You have to run an electric fan ..... my personal one is off an 87 ford taurus.... 120 amp fan....
Now with my bracket I used for my clutch I had to have a suspension lift of at least 6 inches........
but After I re did it I could probably use a 4 inch lift ... but I like mine.
You see I never wanted to be this big
prices
engine- 650
misc stuff that i can't think of - 300
adaptor - 350 for rush
bellhousing -90
So in all I spent 2000
and that included 500 bucks I spent for the shop I kinda rented.
It took me about 3 weeks total to get mine done... but if you have everything and have the time I would say about 2 weeks
tools
torches
welder
sockets and wrenchs
manuals
I may have forgotten some stuff so any questions let me know
97 TJ : 5.0 HO with skyjacker 6" RR 2.5 body lift ,38x12.5x15 superswamper TSL's. 8.8 rear end
proud supporter of jeep forums
Green Jeep Club Member #4
drtjmpr17 is offline
post #2 of 54 Old 08-17-2002, 10:42 PM
Scafone
Scafone's Avatar
tj/5.0 swap
Nice work. I've been contemplating the same swap in my '98/2.5L--can't stand not having any power!! I was wondering how your tranny is going to hold up and is that the same one Jeep used for 4.0L and the 2.5L? My plan is to use the 302/AOD from my Grand Marquis and either get ahold of a Ford t-case or get an adapter for the NP231. See, I always thought the trans behind my 2.5L was way too weak to support any V8. Although, the way you did it seems like it might be easier. Also, any tips on the wiring end...not looking forward to figuring that one out. I have all the wiring, computer, etc. from the 'Merc and I was hoping to use it instead of going the "Painless" route($$$toomuch$$$). Oh, about your body lift...was that necessary and did you have to go 2 1/2 inches high?
Thanks, I'll let you know what I do.
Scafone is offline
post #3 of 54 Old 08-18-2002, 11:01 AM Thread Starter
drtjmpr17
drtjmpr17's Avatar
Well I have the ax-15 with the 231 transfer case... and I broke a driveline and a yoke... and when I thought I took out my tranny it was actually my throw out bearing... and I pulled my tranny apart and found no metal shavings... And I am very surprised to see this tranny hold up so well.
Now if you want to do this swap stout...
5.0 ho engine
t-18 transmission
and a 205 transfer case
bombproof setup
all ford and your pumpkin is on the left side drivers
post #4 of 54 Old 08-18-2002, 12:06 PM
Scafone
Scafone's Avatar
I did't expect to find a 5.0 TJ guy...
I was starting to wonder if I should get too deep into this project since I hadn't seen anyone else doing it. Any regrets? And do you think you would go with that T18/NP205 setup if you did it over?
Which Fords came with the T18(I don't even know if its a auto or manual) and the 205? I'm guessing its a manual out of an F150/Bronco, and also which years?
Scafone is offline
post #5 of 54 Old 08-21-2002, 04:24 PM
GEAH
GEAH's Avatar
1974 CJ5
Re: tj/5.0 swap
I was considedring using the AOD but the adapter is $640.00.
and you can find a complete drivetrain that will work for less than that.
I found an np435 with an np205 complete for $200. Keep you eye out in the local trader papers
74 CJ5
304CI
3spd
GEAH is offline
post #6 of 54 Old 08-22-2002, 11:30 PM Thread Starter
drtjmpr17
drtjmpr17's Avatar
I still plan on putting a t-18 manual transmission --( 4 spd granny low ) to a married 205
just haven't had the time to put it in.....
Also if you do an automatic..... I would go with a c6 just cause its a strong tranny... You should be able to find one married to a 205
way stronger and cheaper than a 231...
try to find a 70s ford to get these parts from,,, and bring a ford tranny number book if you junk yard hop... t 19 looks just like a t 18 -- only difference is the gears
jeep t 18 have a long shaft, not good for us short wheelbases
post #7 of 54 Old 08-23-2002, 12:56 PM Thread Starter
drtjmpr17
drtjmpr17's Avatar
Yeah the ax-15 that I have has held up pretty good so far...
And I have around 325 horses pumping into it
post #8 of 54 Old 09-08-2002, 09:00 AM
V8wrangler_idaho
I would stay away from the aod tranny they suck the stock jeep trannny is stronger then they are. not to mention fixing anything on an aod would be spendy. I check prices on them and its a joke. On my 302 swap I went with a truck 4 speed out of an 84 ford bronco. T18 tranny and the np205 transfer case off the same vehical. fits fine.
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
post #9 of 54 Old 09-08-2002, 09:52 PM
Scafone
Scafone's Avatar
Ford fan??
I know from being familiar with Fox Mustangs that the AODs in a mustang can handle gobbs of power. Depending on how much power you're putting through it, that trans can be built to handle it.
But anyway, for my application, my motor will probably only put out around 200 hp (initially). I'm still researching my options, but I still think my AOD will be ok--and most likely aquire a Ford t-case instead of the adapter/231 deal.
Scafone is offline
post #10 of 54 Old 09-10-2002, 12:28 AM Thread Starter
drtjmpr17
drtjmpr17's Avatar
If you go auto I would recommend getting a C-6 tranny......
they are pretty strong and would handle the abuse of offroad
but if you pavement pound then the Aod is a good choice,
Even occational offroading would be a load on the aod ... seen many a broncos go through those trannies...
price what it would cost to get that aod rebuilt.. then price a manual
aods are super spendy....
post #11 of 54 Old 09-10-2002, 09:16 AM
V8wrangler_idaho
the c6 tranny is really long your drive line angle might be pretty short with a c6 . If i was to go with and auto I would switch over to a chevy 7004r tranny. ITs as short as a t300 and stronger then a t400 and its a 4 speed tranny with a locking torch converter. you can get them with both driver side and passanger side droop tranfer cases. and advanced adaptors makes a bellhousing adaptor for them to mount to the 5.0 that would be my choice for auto. oh and deffently need to go wheeling next time we get together Josh
Daniel Mclay
post #12 of 54 Old 09-10-2002, 09:19 AM
Scafone
Scafone's Avatar
I see your point about the aod. If I go through all of this, I wouldn't want to worry about my tranny breaking.
Did you(s) retain your original driveshafts or at least the same lengths? I've been told when doing a swap to start at the t-case mount so your driveshaft lengths don't change. But then I suppose the overall drivetrain length is the most important.
Oh yeah, I remember a c6 being on the long side. Seems like it would be too long for a jeep.
Scafone is offline
post #13 of 54 Old 09-10-2002, 09:23 AM
Scafone
Scafone's Avatar
...you answered my question before I sent it out...
I think I'll look into getting a t18/205.
Scafone is offline
post #14 of 54 Old 09-10-2002, 09:25 AM
V8wrangler_idaho
my rear drive line lenth changed on my convertion. the drive line accually Is longer now with the convertion. the front drive line is just a little shorter then it used to be. and with the np 205 tranfer case it already has the slip yoke eliminator on it. so i was able to put on a better drive line.
Daniel Mclay
post #15 of 54 Old 09-19-2002, 06:47 PM
2J's
Very cool. I have a 89 5.0 H.O. that I hoped to put into my 81 CJ7. My problem is that I am in So. California( No, I'm NOT happy about it) I lucked out and got the complete wiring harness and computer and everything I need for the smog caca. Now I just gotta do it. Your post will be helpful. One question....how did you handle the fuel injection pump? Did you get a new fuel tank or find something aftermarket? I haven't researched it that far yet. Any one got any input?
Thanks.
2J's is offline
need engine conversion wiring diagram 91brYJ Engines & Drivetrain 0 12-15-2009 07:03 PM
engine conversion???? green_jeep Engines & Drivetrain 7 04-04-2006 11:03 PM
Engine conversion questions HELP PLEASE! Franken-Jeep Engines & Drivetrain 5 08-12-2002 09:18 PM
Engine Conversion question.... Franken-Jeep Engines & Drivetrain 4 07-11-2002 09:21 PM
