48" Press Brake Project - Page 7 - JeepForum.com
post #91 of 203 Old 02-08-2012, 08:32 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hmmm.. I think the valve had a closed center position.. if not, I'll swap it out. It also has a "detent" in the retract position so you can just hit the lever up and the die will raise all the way until it bottoms.. then it automatically snaps the lever back to the center position. I'll probably make an adjustable stop to trigger the detent low in the range of motion to help keep cycle times down.
Wouldn't surprise me if there's some stuff I'll have to revamp/replace. I'm not a hydraulic whiz so I'm kinda shooting from the hip on this..
BESRK is offline
post #92 of 203 Old 02-09-2012, 12:47 AM
dodger889
Originally Posted by Abaddon View Post
this is looking good
one thing i just noticed and must of over looked before is that your using a log splitter value
i dont know how your rams will be positioned but i used a log splitter value on a custom scissor lift i made for a customer and had to swap it out as it wouldnt stay in the up position (scissor extended up has ram retracted)
i ended up switching every thing out and and using a value with a closed center
the only reason i mention it is it doesnt do any good if your punch keeps wanting to rest in the die while your tring to set up a bend but like i said i dont know how you have it planned out and it might work fine but if you run into problems i can give you the company name and part numbers i use and a Reps. number if youd like theres prices were pretty good for the custom package i buy from them
More than likely he will be using power up and down. So the hydraulics will hold the head up will the proper valving with good hydraulic cylinders.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #93 of 203 Old 02-09-2012, 07:34 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Yep.. power up/down.. with a brand new 5" cylinder. I should be able to start putting the pivots and hydraulic system together in the next week or so..
BESRK is offline
post #94 of 203 Old 02-09-2012, 01:09 PM
82JeepCJ7
1982 CJ7
Here is the one in our shop
Cincinnati 400 ton
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #95 of 203 Old 02-09-2012, 01:43 PM
addicted2dunes
1981 CJ8
Cincinnati 400 ton
Looks like that thing can only bend up to 16 gauge though...... we need something a little stronger.... ha ha j/k
Cameron Gunlock
1981 CJ8 -
http://www.facebook.com/pages/Central-Coast-Krawlers/139075302856004
addicted2dunes is offline
post #96 of 203 Old 02-09-2012, 02:03 PM
firefighter315
Cincinnati 400 ton
How WIDE is that thing? Holy crap!
My YJ Build Thread
firefighter315 is offline
post #97 of 203 Old 02-09-2012, 03:27 PM
82JeepCJ7
1982 CJ7
It has a 16' bed on it.
We have bent 2" on it before, about 10" wide.
We normally bend 1/2" to 3/4" 144" wide for our buckets on it.
I like the simple design of it. The only moving parts are the cylinders. The hydraulics are run though a T so they feed each side the same.
post #98 of 203 Old 02-09-2012, 04:11 PM
addicted2dunes
1981 CJ8
Those rams look to be about 2.5" in diameter! Monsters!
Cameron Gunlock
1981 CJ8 -
post #99 of 203 Old 02-09-2012, 04:33 PM
monkers
2010 JK Wrangler
Beserk, we had a valve body like that on our wood splitter my dad built years ago with the "detent" in the return. He was anal retentive and cut all his logs 16" (had a marker to make a mark on them) so I machined an alum sleeve for him that bolted around the rod, he put it where he wanted it. When you split a piece, you just hit the lever, and it retracted, unitl that alum sleeve was contacted....worked great. You could use thumb screws in the sleeve so it was easily adjustable so you didnt have to retract the full length each time, just the amount needed for that particular bend
2010 Rescue Green 2 Door 6 Spd, 2.5" RK Max Travel, Fox 2.0 IFP Shocks, 37" Nitto Trail Grappler M/T, EVO Sleeves, Gussets, Mini Skids, Rock Stars, Poly Perf Long Travel Upper Shock Mounts, Poison Spyder Evap Skid, Diff Covers, Grab Handles, Cobra 75WXSt, Stern Cibie/Osram Light Upgrade, Mopar Heated Seats, Trimmed Flares & Bumpers
monkers is offline
post #100 of 203 Old 02-09-2012, 06:49 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'll probably just do a threaded rod (1" bolt about 6" long) that makes contact with the main punch plate somewhere to trigger the detent. A jam nut to hold it in place should make it easy to use.
My suction and return hoses for the hydro system came in today. If I get a chance, I'm going to hit Northern this weekend and try to pick up all the fittings/adapters that I need to start connecting stuff. I'm also going to cut the mounting plate for the Electric Motor/Hydro Pump and Reservoir this weekend.
So... if all the moons line up correctly, I should have the main frame finished and mounted to the legs permanently this weekend.
BESRK is offline
post #101 of 203 Old 02-09-2012, 06:58 PM
tdkask
Have a first project in mind yet? I do.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #102 of 203 Old 02-09-2012, 07:37 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
David, can you give me a call tomorrow?.. I broke my Droid last week and lost all my contacts. Just got a new phone the other day..
BESRK is offline
post #103 of 203 Old 02-09-2012, 07:40 PM
tdkask
Will do. Also just texted you.
EDIT: P.S.- buy an iPhone!
tdkask is offline
post #104 of 203 Old 02-13-2012, 05:52 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Made a quick adapter for mating the hydraulic pump to the electric motor. Northern wanted $70 for theirs.. I was able to make this one from scrap..
Took about 10 minutes to measure everything, 10 minutes to draw it all up.. and 4 minutes to cut.
Motor side of adapter..
Pump side..
All bolts and set screws are easily accessible..
Tacked together and mocked up..
BESRK is offline
post #105 of 203 Old 02-13-2012, 06:01 PM
addicted2dunes
1981 CJ8
Awesome!
Cameron Gunlock
1981 CJ8 -
My little 9" Press Brake Project BESRK Fabrication Shop 41 11-18-2014 08:36 AM
DIY HD Hydraulic Press Brake webdog Fabrication Shop 66 06-01-2012 01:27 AM
press brake pictures papa355 Fabrication Shop 8 04-15-2012 03:36 PM
36" Shop Press/Press Brake 1995Moneypit Fabrication Shop 6 01-20-2012 03:12 PM
My DIY press brake JOExFROMxNY Fabrication Shop 8 12-10-2010 09:43 AM
