48" Press Brake Project - Page 5 - JeepForum.com
post #61 of 203 Old 12-02-2011, 05:09 PM
addicted2dunes
1981 CJ8
Originally Posted by Jason View Post
Eddie- Dumb question, but I'm curious. How did you cut the X's?
It's all CNC plasma'd
Cameron Gunlock
1981 CJ8 -
http://www.facebook.com/pages/Central-Coast-Krawlers/139075302856004
addicted2dunes is offline
post #62 of 203 Old 12-03-2011, 05:57 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Yep.. basically, I imported the JPEG of the Iriquois Brake, traced it in CAD. Separated the parts (arms, shackles..etc.) and then started tweaking everything to fit the 4x8 sheets of steel. Probably have about 8hrs into the CAD drawings.. alot of it just sitting there looking at the screen. All the "X"s were added last. Took about 5 minutes to draw them and lay them out where I wanted them..
BESRK is offline
post #63 of 203 Old 12-03-2011, 03:30 PM
KMD
1976 CJ7
Originally Posted by webdog View Post
Looks great!
If I end up with 1 more piece of equipment I will be forced to get a shop, I have been looking for one and just cant decide when is the right time to pull the trigger...
Wait till you can afford a bigger shop than you need lol.
This brake is going to be so cool,can't wait to start building mine.
KMD is offline
post #64 of 203 Old 12-03-2011, 03:56 PM
webdog
DirtBound Offroad
1990 XJ Cherokee
Oh yea, I am in a 350 sq ft garage right now. I am looking at 1500sq ft minimum...
webdog is offline
post #65 of 203 Old 12-04-2011, 02:04 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Worked on that warped main punch plate today. I used a bottle jack and some chains to pull it straight and then welded one of the outer plates in place. The plate originally had a bow of about 3/4". Once I welded the outer plate in place, it was actually pulled back too far in the opposite direction by about 1/16". I'll fix that when I weld the opposite outer plate in place.
Here's the one outer plate in place..
Here's my straightedge laid up against the plate.. you can see how it pulled it up just a bit too far at the ends.. I'll take care of that when I do the other side..
Really enjoying this Hobart Ironman 230..
BESRK is offline
post #66 of 203 Old 12-04-2011, 03:29 PM
jatepper
Man those are some ugly welds!!! j/k. Outstanding job as always.
I'm starting on my mini-BESRK brake this week.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #67 of 203 Old 12-04-2011, 03:36 PM
Jim1611
Jim1611's Avatar
Nice work Eddie. Hey what's the rabbit ear looking grooves around the holes for?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #68 of 203 Old 12-04-2011, 04:15 PM
addicted2dunes
1981 CJ8
I'd guess just a rosette weld spot near the holes to keep the plates from separating?
Cameron Gunlock
1981 CJ8 -
post #69 of 203 Old 12-04-2011, 04:16 PM
addicted2dunes
1981 CJ8
Yeah, you should stop while you're ahead and just ship this one to me
Cameron Gunlock
1981 CJ8 -
post #70 of 203 Old 12-04-2011, 05:30 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Yeah.. they're just to tie the pivot tubes into the center plate with a little bit of weld..
As an afterthought. It would've worked better to cut the hole in the outer plates to leave about a 3/8" gap that could've been filled in with weld around the entire pivot tube.. oh well..
BESRK is offline
post #71 of 203 Old 12-06-2011, 05:12 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Got a little bit done this evening..Originally, I was just gonna laminate 2 pieces of 3/8" together for the shackles and arms. However, changed my mind and went with 3. I got one shackle welded up today and turned a couple pivot tubes for it. My son is gonna cut the rest of the pivot tubes tomorrow and we'll continue to weld stuff together.
Still waiting on the bushings..
How'd you like to bolt a set of these shackles under your YJ?
BESRK is offline
post #72 of 203 Old 12-07-2011, 05:42 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Just ordered $900 worth of hydraulic parts.. 5hp motor, pump, valve, couplers, reservoir, filter..etc.
Once I get it all situated, I'll pick up all the hoses.
Merry Xmas to me, Merry Xmas to me..
BESRK is offline
post #73 of 203 Old 12-27-2011, 08:10 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Cut some more 1/2" plate. I cut some additional material to add to the bottom of the main frame (to reduce deflection) and also cut the punch plate guide plates.
My crane.. straining..
Here's the guide plates in place. There will a strip of 1/4" thick plastic bolted to the inside of each plate to act as a "wear" plate for the punch plate. I just ordered the plastic a few minutes ago..
BESRK is offline
post #74 of 203 Old 12-28-2011, 06:26 AM
Jim1611
Jim1611's Avatar
Along with the crane straining I see a nice addition riding along side the driver.
My build thread
Jim1611 is offline
post #75 of 203 Old 12-28-2011, 07:36 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I need to make a forklift saddle holster for it..
BESRK is offline
My little 9" Press Brake Project BESRK Fabrication Shop 41 11-18-2014 07:36 AM
DIY HD Hydraulic Press Brake webdog Fabrication Shop 66 06-01-2012 12:27 AM
press brake pictures papa355 Fabrication Shop 8 04-15-2012 02:36 PM
36" Shop Press/Press Brake 1995Moneypit Fabrication Shop 6 01-20-2012 02:12 PM
My DIY press brake JOExFROMxNY Fabrication Shop 8 12-10-2010 08:43 AM
