48" Press Brake Project - Page 14 - JeepForum.com
post #196 of 203 Old 05-29-2012, 12:59 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Originally Posted by aresfab View Post
How did you do the d-ring mount?
The clevis mount comes thru the bumper alongiside an inner rib. Also, the lower bumper mount (not shown), catches the other side of the clevis mount. So.. the mount is tied into the bumper, the gusset, and the lower mount.
Originally Posted by jatepper View Post
Eddie,
You have outdone yourself once again. As always, unbelievable work my man! I can appreciate not having to do that kind of grinding!
Just one question...what you you doing to bend the front piece back to meet the top and the bottom pieces?
Thanks Jeremy, I just score the ends with a cutoff wheel and push them into place by hand. Then, I run a bead along the score and blend it in.
BESRK is offline
post #197 of 203 Old 08-06-2012, 07:05 PM
aresfab
Updates
[CENTER]ARES FABRICATION
aresfab is offline
post #198 of 203 Old 08-07-2012, 05:52 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'm embarassed to say.. no updates.
I still haven't put the finishing touches on this thing (finish welding and paint). I've just been using the snot out of it. Have bent up a few dozen winch plates and at least several hundred small brackets. This is one of those machines that's so useful, you're afraid to have it down for even 1 day.
I think future plans will include 3" and 3.5" dies.. for bending some 3/8" and 1/2" thick brackets..
BESRK is offline
post #199 of 203 Old 10-08-2013, 01:08 PM
tdkask
Anything? You still using this thing?
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #200 of 203 Old 10-08-2013, 05:10 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hey! Long time no see!!
Yep.. use it almost daily. I still haven't gotten around to shooting paint on it though.
I've probably done at least 1000 bends with it so far.. brackets, winch plates, bumper pieces..etc.
I need to invest in more dies.. maybe some wider dies for 3/8" and 1/2" plate.. and some gooseneck dies for deep bending. I also want to make a die holder for my dimple dies. Just gotta find the time.
BESRK is offline
post #201 of 203 Old 10-08-2013, 09:20 PM
firefighter315
Paint must be on the list somewhere behind the oven.
kiddin' man, just kiddin', that just means business is GOOD!
My YJ Build Thread
firefighter315 is offline
post #202 of 203 Old 10-10-2013, 06:20 AM
tdkask
Haha. That oven was in work the first time I was ever there. You've been working on that idea as long as I've been busing the same set if axles.
tdkask is offline
post #203 of 203 Old 03-04-2016, 09:20 PM
webdog
DirtBound Offroad
1990 XJ Cherokee
So how is this press holding up?
I am finally planning to start building one, but a little bigger.
Looking to do a 72" 90 - 100 Ton setup, still got a ways to go on the design.
webdog is offline
My little 9" Press Brake Project BESRK Fabrication Shop 41 11-18-2014 07:36 AM
DIY HD Hydraulic Press Brake webdog Fabrication Shop 66 06-01-2012 12:27 AM
press brake pictures papa355 Fabrication Shop 8 04-15-2012 02:36 PM
36" Shop Press/Press Brake 1995Moneypit Fabrication Shop 6 01-20-2012 02:12 PM
My DIY press brake JOExFROMxNY Fabrication Shop 8 12-10-2010 08:43 AM
