36" Shop Press/Press Brake - JeepForum.com
post #1 of 7 Old 01-18-2012, 07:31 PM Thread Starter
1995Moneypit
Winter is dragging up here in Michigan and my ADHD is really kicking in. Thinking of some new projects and expanding my home shop capabilities and was considering building a shop press. I've looked at the HF one and some of the nicer presses at a local machinery supplier and the basic structure seems pretty simple. In the early stages of designing it and wanted some opinions to see if I'm going the right direction with this.
I would like to be able to bend up to 3' length of 3/16" stock for bumper fabrication. Looks like 20-ton units can bend up to 15", so originally I thought about constructing one with (2) 20-ton bottle jacks with a lever assembly to connect the two pump handles. I'm concerned that one might "age" differently than the other and end up with uneven pressure accross the press. Now, I'm thinking of just going with (1) 50-ton bottle jack.
Any thoughts or experiences with building something like this? Is the 50-ton going to be enough to put some decent bends in 3/16 to 1/4" material @ 36" long?
1995Moneypit is offline
post #2 of 7 Old 01-18-2012, 10:06 PM
97xjsam
Im no engineer but I use a 40ton press for bending and breaking weld test specimens that are up to. 500wall and it works great....the only problem I can see is being able to evenly apply pressure on a 3' long piece of material so it bends correctly
97xjsam is offline
post #3 of 7 Old 01-19-2012, 05:43 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
With a 1.5" bottom "V" die, you'll need about 11.2 tons per linear foot to bend 3/16". You should have no problem doing 3ft of 3/16" if set up properly.
BESRK is offline
post #4 of 7 Old 01-19-2012, 05:43 PM Thread Starter
1995Moneypit
Thanks. I was hoping someone had a formula like that. The presses I've seen have a solid rod at the center for the press point. What about installing additional contact points to help distribute the weight across the brake jig.
Not sure if I can mention a different forum, but I think I saw a post on another 4 x 4 forum that showcased a 48" press brake you fabbed up. That one looked great!
post #5 of 7 Old 01-19-2012, 08:51 PM
webdog
1990 XJ Cherokee
Here is a link to the one I made with the Swag Offroad 37" die and 2 20ton bottle jacks.
http://www.jeepforum.com/forum/f37/d...brake-1284963/
webdog is offline
post #6 of 7 Old 01-20-2012, 05:54 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Here's a useful table for calculating tonnage requirements...
Tonnage Requirements
BESRK is offline
post #7 of 7 Old 01-20-2012, 02:12 PM Thread Starter
1995Moneypit
Thanks for the link. That will be very helpful. Also, it looks like an assortment of dies is needed to bend the different thicknesses.
My little 9" Press Brake Project BESRK Fabrication Shop 41 11-18-2014 07:36 AM
Looking to buy a shop press JOExFROMxNY Fabrication Shop 10 10-27-2011 09:04 PM
Shop press-- How big? bikepharmer Fabrication Shop 13 01-09-2011 11:59 AM
metal shop/press brake help... theGiantPanda Fabrication Shop 9 08-25-2010 11:45 PM
Shop Press? SuperWade2 Fabrication Shop 15 04-07-2010 06:56 AM
