$30 TJ Fold Down Tailgate (and stuck torx bolt removal) - Page 8 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > $30 TJ Fold Down Tailgate (and stuck torx bolt removal)
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 04-14-2012, 08:14 PM   #106
chefman
I just measured right and left of the tailgate. It looks super weird at first, cause the vent hole ain't quite center. But I ran the cables through the hole in the tailgate for the original wiring, then took them in the hollow area instead of completely through, and had the third brake light and my liscence plate light come through the vent hole just above my plate. I just used a cheapo liscence plate holder and frame from advance. Been solid since. I would like to have a solid piece of aluminium diamond plate for the tailgate and matching corners, but the powerball ticket I buy just keep saying the wrong thing, or maybe they are just picking the wrong numbers.....
chefman is offline   Reply With Quote Quick reply to this message
Unread 04-14-2012, 08:25 PM   #107
chefman
Originally Posted by NalinMFG
how did you go about recentering your license plate? I've been meaning to to mine, this is what I have so far:
(Left: TJ, Right: JK)
Just saw your vent cover on your website. Very sharp!!! Cause I was using a 18" LED third brake light, I needed the liscence plate to be centered on the brake light, and the brake light centered on the left/right lights. If you don't intend on having a third brake light, or don't need things symmetrical, then those designs would work well, but otherwise you'd need to have a certain amount of optical illusion to accomplish a centered plate. I'll try to upload some pics tomorrow afternoon.
Unread 04-16-2012, 09:08 AM   #108
chefman
You can see how the centering of the third brake light and liscence plate makes things look a little askew. I should've attached the plate with hinges in case I'm carrying anything that would need to have the tailgate down, but so far just not having the spare and third brake light sticking up in the center has been working very well. I use my TJ more as a pickup than an SUV, and as with most things in my life, form filled function. Eventually I'll have a piece of sheet metal or aluminum diamond plate cut to fit, covering the holes and dimples. Swag makes one, but now I have the hardtop without a good way to lock the glass (no tire), I'll have it cut to come up another inch to secure everything.
Unread 04-16-2012, 09:11 PM   #109
ryan6580
I made a drop down also! Super cheap!
ryan6580 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2012, 10:13 PM   #110
NalinMFG
did you drill all the way through and use nuts on the inside of the tailgate? I made one almost exactly like that for a buddy of mine a few months ago, yours turned out pretty slick!
[URL="http://www.NalinMFG.com/"][SIGPIC][/SIGPIC][/URL]
[URL="http://www.jeepforum.com/forum/f43/tj-5-25-speaker-adapters-nalinmfg-1325275/"]5.25" TJ Speaker Adapters[/URL]
[COLOR="DarkOrange"]
Linkedin:[/COLOR] [URL="http://www.linkedin.com/pub/andrew-nalin/30/65/825/"][B]Andrew Nalin[/B][/URL]
[COLOR="DarkOrange"] Email:[/COLOR] [B][email]NalinMFG@gmail.com[/email][/B]
[COLOR="DarkOrange"]Website: [/COLOR][B][URL="www.NalinMFG.com"]www.NalinMFG.com[/URL][/B]
[COLOR="DarkOrange"]Facebook: [/COLOR][B][URL="www.Facebook.com/NalinMFG"]NalinMFG[/URL][/B]
NalinMFG is offline   Reply With Quote Quick reply to this message
Unread 04-17-2012, 05:55 AM   #111
ryan6580
Well I used a good self tapper. The setup was supposed to be temporary but its worked good so far I just left it. I'll eventually put a tramp stamp under it and do it the correct way.....lol
Unread 04-22-2012, 09:34 PM   #112
NalinMFG
Here's what I ended up with for mine:
Unread 07-06-2012, 07:47 PM   #113
Doubblea
I love this...just need a swing out tire carrier first.
"The beauty of the Second Amendment is that it will not be needed until they try to take it." -Thomas Jefferson
Doubblea is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 06:24 PM   #114
kylo
Just finished mine. I used nutserts and countersunk stainless steel bolts. And just painted the old hinge locations. I love how it turned out.
kylo is offline   Reply With Quote Quick reply to this message
Unread 08-17-2012, 11:50 AM   #115
AngryTJ
pics on the first page dont work fyi
This thread needs more pics
What did people use to attach the cable to the inside tub of the jeep? Also does the latch open properly without any modification since it was not designed to open downward?
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 08-17-2012, 12:27 PM   #116
NalinMFG
They still show up for me- source link still exists for each.
I should be posting a few this week...have a few things for my tailgate on the laser as we speak.
I'm looking for some different hinges if anyone has input...no problems with the ones on it though. I would just like to have something more professional looking this time around.
Detachable, greaseable, friction(works like a laptop hinge), open/close assist, or anything else you can think of are all still on the table. I will laser cut the hinge's hole pattern into the skin so that everything squares up easily. The plan is to drill straight through the tailgate and use some 2"ish bolts to secure it. This method will be MUCH stronger than self tapping screws...I'm unsure about the "tramp stamp" area for production purposes. I have a fuel cell so it's easy for me to use regular bolts/nuts behind it....most everyone else has a gas tank and would need to use rivets or nutserts.
No issues with the latch.
Unread 08-17-2012, 12:43 PM   #117
AngryTJ
it could possibly be my work computer not showing them for whatever reason, thanks
Unread 08-17-2012, 10:48 PM   #118
higgins192
Could I have your old hinges?
higgins192 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2012, 12:54 PM   #119
NalinMFG
I ran across some real slick looking heavy duty hinges while working on another project today -- they're for service doors, refrigerators, freezers, and industrial enclosures(and has a nylon bushing for smooth operation.). I may grab a pair and make a skin for the whole tailgate/trampstamp area.
Unread 10-02-2012, 06:14 PM   #120
NalinMFG
start of my new tailgate project
Deciding on hardware.
fold down , mod , tail gate , tj
