04-18-2011, 09:46 PM
#91
What about using the existing upper hinge as a latch?
04-22-2011, 07:18 AM
#92
Hey im trying to finish my tailgate today im going to pick up the cables. How did you attach the cables inside the tub? And on the drivers side of the tailgate? I see passanger side of the tailgate is the angle iron. Not sure but.in the tub looks like maybe another self drilling or drilled a hole with nuts bolts and washers?
04-23-2011, 10:26 AM
#93
Tigertrack used 1/2" bolts, washers and nuts, bolted through the tub. Coyote used gate brackets screwed to the tub and the cables looped through them. Use angle iron on both sides of tail-gate.
04-24-2011, 11:14 AM
#94
Thats freaking cool
04-24-2011, 02:00 PM
#95
Vendor
I used an existing bolt from the tailgate latch mechanism.
#96
Some Call me RockDog
If this were Facebook, I would click Like
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
My TJ Build Thread.
www.kifourwheelers.com
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
04-29-2011, 09:27 AM
#97
Finished mine on Wednesday. I like it for loading up stuff.
04-29-2011, 07:18 PM
#98
hey wanta..... can you give me a close-up of the 2 attachments on the inside of the tub? haven't finished mine yet and yours looks very clean
04-29-2011, 10:02 PM
#99
What did you use for hinges? Looks like they have three bolts per side of the hinge it looks like.
10-24-2011, 07:50 PM
#100
Vendor
just regular fence hinges from the local hardware store.
10-24-2011, 11:05 PM
#101
Great idea, looks like it works well.
If any of you TJ guys that have done this still have the stock hinges sitting around and wouldn't mind getting rid of them shoot me a PM.
04-01-2012, 12:20 PM
#102
Vendor
Update: over 1-1/2 years without an issue.
04-02-2012, 04:31 AM
#103
Inspired by this thread, I've done a similiar drop down tailgate using nutserts. Then I relocated the liscence plate to the center and added a led third brake light bar across the top of the edge. Then I had to add an in-bed tire carrier, which I wasn't happy with and ended up making a deck cover and securing the spare above it. Ok, I'm rambling... But just wanted to say thanks for inspiring one of my first mods.
04-13-2012, 01:21 AM
#104
Definitely a mod that is on my list
"The beauty of the Second Amendment is that it will not be needed until they try to take it." -Thomas Jefferson
04-13-2012, 06:57 AM
#105
Vendor
how did you go about recentering your license plate? I've been meaning to to mine, this is what I have so far:
(Left: TJ, Right: JK)
