$30 TJ Fold Down Tailgate (and stuck torx bolt removal) - Page 5 - JeepForum.com
post #61 of 142 Old 02-22-2011, 05:41 PM Thread Starter
NalinMFG
mine still works great
Originally Posted by asjeep View Post
I realize it has been many months since this thread started, but has anyone had any issues after doing this? Just got my swingout done and can't wait to have a drop down tailgate!
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #62 of 142 Old 03-12-2011, 08:50 PM
asjeep
half way through the install now... had to stop for the day before the brackets on the inside are fabbed and mounted... but it folds down now (just doesnt stop without the insde done ) Bought the green HF nutsert tool and bent it.... took it back got the red one... works much better IMHO... Thanks for the great idea!
2002 TJ SE
asjeep is offline
post #63 of 142 Old 03-12-2011, 10:01 PM
paintballtruck
1979 J-Series Truck
for a cheap nutsert tool you can take a piece of flat steel drill a hole the next size up from your bolt in it and use a longer bolt of that size with a couple washers between the head of the bolt and the flat then screw your nutsert on the back side and use a ratchet or i use a small impact to tighten it up just have to make sure you dont overdo it and strip it out i use one everyday at work to do these on semi trucks and trailers much cheaper and if you break it just get another bolt or a new piece of flat bar
paintballtruck is offline
post #64 of 142 Old 03-23-2011, 06:29 PM Thread Starter
NalinMFG
do you have a picture or link for others? i couldnt find the green one on their website
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #65 of 142 Old 03-23-2011, 09:33 PM
asjeep
This is the green one
http://www.harborfreight.com/3-in-1-...kit-94100.html
personally i prefered the red one linked earlier in this thread.... the green one bent on me.....
still havent finished my build yet.... did you make that bracket on the inside of the gate (silver steel one with 6 bolts) or did you buy it somewhere?
2002 TJ SE
asjeep is offline
post #66 of 142 Old 03-26-2011, 07:49 PM
baloo13
(18) self tapping #14 3/4" sheet metal screws
(2) self tapping #14 1" sheet metals screws
(1) 5/16" nut and bolt
(2) 1/2" nuts
(4) 1/2" washers
(2) 1/2" 1.5" bolts
(2) fence hinges
(2) 90 silverado tailgate cables (or whatever else...i used 15" ones)
(1) little piece of angle iron (i used 3" of 1.5"x1/4")
i had some hardware laying around, but this should be around a $30 mod.
stuck torx bolts huh?
clean the surface of the bolt of with a drill bit
weld on an "L" that you can stick a cheater bar onto
break that sucker free
factory hinges off tailgate
used tab as a spacer to keep both sides level
pilot hole for center bolt on hinge (i came in 4" from the outsides)
hinges on
hinges completely on
used a 3" section of 1.5"x.25" angle for the passenger side
tested 360lbs without problem (my dad and I).
Doesn't the none latched side rattle and not close well?
baloo13 is offline
post #67 of 142 Old 03-27-2011, 04:37 PM
G04Rubicon
Awesome i'll probably be doing that to my jeep next
G04Rubicon is offline
post #68 of 142 Old 03-28-2011, 08:22 AM
KLT88YJ
Any long term updates? I Have a CJ-7 tail gate painted and ready to go for my YJ. But I'm really liking this.
KLT88YJ is offline
post #69 of 142 Old 03-28-2011, 12:38 PM
asjeep
on mine even with a hardtop on I have had no rattles... it closed real tight..... i still havent put in the cables.... evertime i start to work onit my back tries to go out... maybe thats a sign.....
2002 TJ SE
asjeep is offline
post #70 of 142 Old 03-28-2011, 12:57 PM
KLT88YJ
Haha!! Its always something....! Well that's good to hear. I run both hard and soft tops.
Thanks again!
KLT88YJ is offline
post #71 of 142 Old 03-28-2011, 08:40 PM Thread Starter
NalinMFG
how could it rattle? the entire mating surface is rubber weatherstripping...
klt88yj- i still do not have a singe complaint about mine.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #72 of 142 Old 03-28-2011, 08:44 PM
KLT88YJ
Well that's cool!! Both guys that did the swap Have good track records with it!! Definitely gonna start gathering parts thanks guys!!
KLT88YJ is offline
post #73 of 142 Old 04-05-2011, 09:01 PM
89Jeeper
I'm in too gotta get around to it this summer. I mean $60 for an awesome mod. sounds good to me!
89Jeeper is offline
post #74 of 142 Old 04-10-2011, 03:35 PM
Cooter92YJ
What do you guys think about using an old set of hood hinges instead of buying gate hinges? I know they wouldn't have as many screws/bolts holding them on. Maybe a drill would make short work of that, just pop in a few more?
Cooter92YJ is offline
post #75 of 142 Old 04-11-2011, 09:57 PM
coyote_94yj
coyote_94yj's Avatar
Oh, now that is a good idea. When I armor up my Jeep I think I will replace the ones I have now with hood hinges or door hinges.
Thanks Cooter.
coyote_94yj is offline
fold down , mod , tail gate , tj
How do I removed a bolt with a stripped torx head? Fargo General Jeep & Off-Road Equipment 11 07-16-2008 11:17 AM
specific torx bit for stripped tailgate hinge bolts? first5.0 General Jeep & Off-Road Equipment 10 05-15-2008 07:51 AM
Help!: Stubborn Torx Bolt in ORF Cage Field88 Fabrication Shop 1 04-04-2008 01:02 PM
Stubborn Torx Bolt on Cage Field88 General Jeep & Off-Road Equipment 1 04-04-2008 08:46 AM
getting out a Torx bolt bigj1974 General Jeep & Off-Road Equipment 5 08-09-2007 09:42 PM
