3" tapered front fender flares - JeepForum.com
post #1 of 7 Old 08-14-2012, 11:50 PM Thread Starter
04WJny
1987 YJ Wrangler
Ive been thinking about the idea of getting some tube fenders for my YJ for a while but dont want to fork over the cash for some when i have the tools to make it. Ive really liked the flares Genright sells and modeled my flares after the tapered look and the perforated vent on the side. I drew some flares in Autodesk Inventor and plan on making some inner fenders as well. I still have a few things that i might change from the modeled drawings below; 1: i might want to put louvers on the side inserts on the fenders 2: make them black or body colored
So far i plan on picking up some 1.25 dia .120 wall 1018 DOM and some .125" thick steel sheet. ill pick up enough so i can make some rear fenders and tube doors in the near future.
ill make the fenders in 3 parts
1: the inner fender
2: the rear of the fender that has the louvered or perforated insert
(it will be welded to the sheet that goes along with the flare)
3: the front of the fender that includes the tube and the steel sheet that
At work ill lasercut some of the parts including the side panel where the preforated insert goes
To bend the tube ill use a 1.25"x90 degree die in a JD2 M32 bender
Any other work will be done with a sander, 4.5" cutoff wheel, 3" grinder with different disks, a harbor freight 90amp flux core welder (to tack stuff up when its on the jeep),and a miller dynasty 200.
Check out the pics below:
Any suggestions would be great
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #2 of 7 Old 08-20-2012, 08:25 AM
drerict
1983 CJ7
I like it. I am planning something similar, no drawings yet.
I saw the poison spider daddy long legs build and they had some fenders before the extended flares that I am trying to emulate.
Eric
Firefighters Jeep Club
drerict is offline
post #3 of 7 Old 08-20-2012, 11:18 PM Thread Starter
04WJny
1987 YJ Wrangler
Eric
Thanks! just checked out the daddy longlegs build and if your making some fenders that look similar to that it should look sick. Ill be watching when you start making yours good luck
2004 WJ I6 4.0L DD
04WJny is offline
post #4 of 7 Old 08-21-2012, 08:33 PM
ssyj94
I was debating trying just about the same fender design the other day. Only thing different was making them with a small highline. I'm looking forward to seeing some progress with these .
My build:
ssyj94 is offline
post #5 of 7 Old 08-22-2012, 09:33 PM Thread Starter
04WJny
1987 YJ Wrangler
Just drew up the rear fenders. Ill be chainging the fronts to 4" flares to match the rear, i think 3" is a little too small Ill be doing all of the fenders at the same time because its cheaper to buy all of the steel at once, and its also easier to use the tubing bender for all of the tubes at once. Heres what the rear ones should look like:
2004 WJ I6 4.0L DD
04WJny is offline
post #6 of 7 Old 03-22-2013, 02:34 PM
Carlos14
Any update?
Luck Favours The Prepared
Carlos14 is offline
post #7 of 7 Old 03-25-2013, 08:51 AM Thread Starter
04WJny
1987 YJ Wrangler
There going to have to wait untill the summer. I've been really busy building my schools SAE Baja car. If I have some free time I will definitely work on them, and have some pics to follow
2004 WJ I6 4.0L DD
04WJny is offline
Borrow a 1.5" tapered TRE reamer? Area.3.Fiftyone Fabrication Shop 4 11-17-2010 05:10 PM
Fender Flares for 31" Tires wranglergirl42 Tires & Wheels 7 05-24-2010 12:28 PM
Fender Flares RHA1583 Tires & Wheels 2 02-05-2006 08:24 PM
fender flares walterphilippo General Jeep & Off-Road Equipment 1 01-14-2005 07:22 PM
Tj fender flares on a Yj porkchop Fabrication Shop 11 11-01-2003 10:23 AM
