2x4 1/4" Rectangle tube for rock sliders - JeepForum.com
post #1 of 14 Old 08-11-2009, 08:41 AM Thread Starter
BigDogg50
Has anyone fab'd any sliders out of this rectangle tubing before? Any pros or cons? Pics of the fab would be great!
BigDogg50 is offline
post #2 of 14 Old 08-11-2009, 08:43 AM Thread Starter
BigDogg50
The tubing is 2x4x1/4".
post #3 of 14 Old 08-11-2009, 09:00 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
for frame mounted sliders, it sounds like a good plan. overkill, and twice the thickness of the frame - make sure you've got lots of gussets holding them on the frame so that doesn't turn into a weak/bending point.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 14 Old 08-11-2009, 06:42 PM
palmrose2
1987 XJ Cherokee
Whenever I start welding up something that is going on a vehicle I consider its weight and what effect it will have on it. I've got rails made from 2" sched 40
pipe. I believe they are .188" thick. I've beat them pretty good and you would never know by looking at them. My front bumper is 3" square tubing that is even thinner and I bounced off a tree @ around 10-15 mph with no ill effects.
Salvaged 87 2 door 2.5L XJ:
Trac-Loc D44, Aussie Locker disco D30
3" lift, 31x10.50 Treadwright Guard Dog Kedge Grip
15x8 4.5 BS Rock Crawler Extreme Steel
What are sway bars?
palmrose2 is offline
post #5 of 14 Old 08-11-2009, 06:45 PM
palmrose2
1987 XJ Cherokee
My point is that you can get heavy pretty quick if you start throwing thick steel at something. Just ponder it.
What are sway bars?
post #6 of 14 Old 08-11-2009, 09:47 PM
zukibud600
Not 2x4 tubing but i used 2 1/4"X 1 3/4" X 1/4" rec tubing. My wife and kids love them because they double as steps!!
zukibud600 is offline
post #7 of 14 Old 08-12-2009, 09:03 PM
Bigboyky
I'm thinking about using 2x4 3/16. 1/4" would be fine also in my opinion
1995 4.0l, 5spd., 4:88's, ARB's F/R, 4"RC lift, homebrew bumpers & tire carrier, homebrew gas tank skid, lined inside, Cobra cb, smitty winch, 130w & 55w Hella lights
Envy our past, Fear our future Go Cats!
Take a look at our club
& here on JF
Bigboyky is offline
post #8 of 14 Old 08-12-2009, 10:07 PM
jpfelix
i'm working on some. we'll see how it works out.
jpfelix is offline
post #9 of 14 Old 08-13-2009, 03:06 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
Search around (don't forget NAXJA and Pirate); there are plenty of writeups that use 2" x 4" rect. tube. 1/4" is overkill though - I'd stick with the 3/16".
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #10 of 14 Old 08-13-2009, 07:56 PM
mnridgerunner
3/16s is plenty thick enough I don't have it on my YJ yet but I've had it on my XJ for three yrs and it is holding up good.
mnridgerunner is offline
post #11 of 14 Old 08-14-2009, 07:01 AM Thread Starter
BigDogg50
Thanks for the help! I'm thinking that is probably a little overkill!! I will probably end up using something a little lighter.
post #12 of 14 Old 08-14-2009, 11:30 AM
1 ton yj
1 ton yj's Avatar
I used 2x3 with 2x.120 tubes to the frame. When you weld the outriggers on to the frame, plate the frame with a 4x4 piece of .188 or .25 plate. Mine ripped out and I had to cut them off and go back and replate them.
Wheeled very hard for 4 years and they didn't budge at all.
1 ton yj is offline
post #13 of 14 Old 05-12-2010, 02:34 PM
will228
will228's Avatar
i want a set of those for my LJ so bad!
will228 is offline
post #14 of 14 Old 05-13-2010, 08:00 AM
IKIndy
Here are the ones I have made and sold for XJ's. TS 2x3 11ga (1/8")
They screw to unibody and bolt down the pinch seam.
[IMG][/IMG]
[IMG][/IMG]
IKIndy is offline
Anyone have square tube rock sliders? 2Xtreme General Jeep & Off-Road Equipment 4 01-11-2010 12:55 PM
Tube Fender and Sliders Help 98VolsTJ Fabrication Shop 1 11-04-2009 11:31 AM
Rectangle Sliders/Steps jboor Fabrication Shop 3 08-28-2009 10:04 PM
POR 15 on rock sliders? Bot General Jeep & Off-Road Equipment 2 04-09-2007 09:15 PM
Rock Sliders emx Fabrication Shop 3 06-03-2005 12:24 PM
