24 x 20 ft Workover tubing shop build. - Page 6 - JeepForum.com
post #76 of 100 Old 12-10-2013, 08:44 PM Thread Starter
Ezalycasaid
Originally Posted by schitzangiggles View Post
Awesome!
How's the healing going?
Thanks man, its going good. Little bit of breathing issues but nothing horrible. Still gotta get my septum un-deviated and I should be finished with all my surgeries.
Old build 99 TJ 100wb on 35s and arbs.
New build D60s, 40s etc.
I void warranties.
Ezalycasaid is offline
post #77 of 100 Old 12-10-2013, 08:46 PM Thread Starter
Ezalycasaid
This build is still moving forward now its time to extend it out 4ft to the right side where the concrete is. Heres a pic of basicly what Im going to do. Ive already got the metal and wood sitting in the garage, Im just waiting for me to have time off from work to do it and clear weather for 3-4days. Ive also got the metal trim for the garage door frame on order. Then Ill add a man door on side of the garage door, wich is also sitting in the shop already. The 4ft wide by 20 long by 7ft high extension is going to be one large shelving system to put all my tools, toolboxes, benders, welder, and cutting bottles on. That way I can easily just slide out whatever I need and still have a 20ft x 20ft area of open space just to work in. Also I found my original drawing I pitched to the gf about what I was gonna build... Its pretty accurate, and 4th grade-ish
I void warranties.
post #78 of 100 Old 12-10-2013, 09:29 PM Thread Starter
Ezalycasaid
Got bored at work. Heres one with the right trim color and a tree.
I void warranties.
post #79 of 100 Old 12-15-2013, 06:55 PM Thread Starter
Ezalycasaid
Havent been able to make any progress on the shop. Ive been working 17hr shifts the past 2 weeks and only had 2 days off since. Wich was spent resting. Anyway my g/f got me a all black hobart autoarc helmet for my bday. So I painted it. Halo colors.
I void warranties.
post #80 of 100 Old 12-19-2013, 03:50 PM Thread Starter
Ezalycasaid
Started trimming the doorway.
I void warranties.
post #81 of 100 Old 01-03-2014, 06:32 PM Thread Starter
Ezalycasaid
Still going forward just REALLY SLOWLY. Finally have money to put into it but no time. Im working 17hr days ever day of the week for the past 5 weeks and I still have about 1 and a half to 2 month of this to go. But the moment I have time off Im extending the side out. Anyway even with 17hr shifts Im still finding time to do some things to it. Did what I think is one of the greatest improvements to the shop, a man door. Im so tired of having to pick that 120lb door up by myself without the springs on it. Now I can work on the garage door springs and not have to have it open to get back out of the shop if I cant fix it. Also its alot easier to heat the shop if only the man door is cracked open. Still need to do some trimming but not too worried about it right now, wierd part is the door just happens to be the same color and the metal siding.
I void warranties.
post #82 of 100 Old 02-08-2014, 02:57 PM
Scott3140
Junior Member
Scott3140's Avatar
You know that your man door is upside down?
Scott3140 is offline
post #83 of 100 Old 02-08-2014, 07:25 PM
Awesome
I think it's hilarious that you guys keep calling it a "man door."
100 Characters is not enough to have an interesting/relevant signature.
Awesome is offline
post #84 of 100 Old 02-09-2014, 06:14 PM
tjcj
What else would they be called? In my 18 years of construction and 1000's I've installed that's what we call them.
Sent from my XT881 freeze ray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #85 of 100 Old 02-09-2014, 07:16 PM
Awesome
It's just a door. Other doors that are (far) less common get descriptors. For example, his garage door would either be a "garage door" or a "roll-up door," though true roll-up doors are different. I find it amusing that people add a descriptor to the most common type of door.
Awesome is offline
post #86 of 100 Old 03-05-2014, 10:52 PM
jameslinn83
Man door or walk door for walking through
Garage door would be an overhead door. At least that's how I've always heard them called
jameslinn83 is offline
post #87 of 100 Old 03-06-2014, 10:22 AM
Renegade82
1982 CJ7
27 years in the home construction business and we've always referred to them as "man doors". It differentiates them from "patio doors", "closet doors", "trap doors", "access doors", and "garage doors".
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #88 of 100 Old 06-24-2014, 09:09 PM Thread Starter
Ezalycasaid
I got some more time off for another surgery for them to put my face back together. Got a little bit done and then ran out of time. Kinda had to make some stuff work. I still have to trim again and do the front section, but I cant until I get time off work and the metal roofing place is open on the same day. I also took everything and put it in the center so I can start making benches/shelves. To this day I've made everything on my crawler without a bench,vice, or anything flat. I should have a lot of storage now and have a wide open 18x20x13tall area of open work space with 6Lx20Wx8T of storage. haha its a little unorganized at this time. If u look at the metal polls on the right side, everything from the metal polls to the right wall is what I added.
I void warranties.
post #89 of 100 Old 06-27-2014, 03:00 PM Thread Starter
Ezalycasaid
Lots and lots of tubing. 15Lx3Tx2W. Putting the expanded on the middle row is gonna suck.
I void warranties.
post #90 of 100 Old 06-27-2014, 06:56 PM Thread Starter
Ezalycasaid
Started the expaned metal middle shelf. Man that was a horrible Idea to do after I put this thing together. Hammers work great to get them in place though.
I void warranties.
