24 x 20 ft Workover tubing shop build. - Page 3 - JeepForum.com
post #31 of 100 Old 03-16-2013, 09:02 PM Thread Starter
Ezalycasaid
Originally Posted by tjcj View Post
I think what he means is if you used say 2 pieces of rebar 10' long to make up 1 20' length, where the two overlap make sure to give it a 12" overlap.
Sent from my XT881 freezeray gun using JeepForum
Oh ok. I only used 20ft long #4 grade 60s. Do u know how to tell if u have grade 60 or grade 40?
Old build 99 TJ 100wb on 35s and arbs.
New build D60s, 40s etc.
I void warranties.
Ezalycasaid is offline
post #32 of 100 Old 03-16-2013, 09:17 PM
tjcj
There is usually numbers cast into the rebar somewhere along it. I wouldn't worry about the grade of the bar. Usually the higher grade is for the government cause money is no object for them.
Yakima Valley Mountaineers.
tjcj is offline
post #33 of 100 Old 03-17-2013, 12:12 AM Thread Starter
Im asking because I supposedly bought grade 60. Atleast I bought it on the computer in the office. Then I walked out to their shop and when I asked the guy handing it to me if he grabbed the grade 60 or 40 he responded with."Idk I grabbed from the rack on the computer, we just started carrying rebar.". Ive bought from them before and theyve givin me the wrong od tubing before. I was just wanting to know if I paid for stronger and got screwed.
I void warranties.
post #34 of 100 Old 03-17-2013, 09:14 AM
TimV
That had to be noisy as crap using a plate tamper on rock. I pity your ears.
Looking good otherwise!
It's not an addiction. It's a way of life.
TimV is offline
post #35 of 100 Old 03-17-2013, 09:52 AM
tjcj
Gotcha if it's 60 there should be a 60 or a 6 with a 0 under it stamped on the bar somewhere . There will also be some letters and a 4 stamped. The letter is who made it and the 4 will be the size (4=1/2", ) . There should also be a straight line running the length of the bar cast into the bar,
tjcj is offline
post #36 of 100 Old 03-17-2013, 11:53 AM Thread Starter
About as noisy as a lawn mower. It doesn't make any loud metal on rock noises surprisingly. I didn't hear the metal or rock at all.
I void warranties.
post #37 of 100 Old 03-17-2013, 02:44 PM
TimV
Wow, I've used one on dirt before and hit a big rock. I thought I broke the thing it was so loud.
TimV is offline
post #38 of 100 Old 03-17-2013, 05:02 PM Thread Starter
Ezalycasaid
Leveled out and framed up a 5x20x3" thick slab for outside the shed.
I void warranties.
post #39 of 100 Old 03-17-2013, 05:34 PM
tjcj
Looks good are you going to make two pours? Reason I ask is if you pour it all at once you either have to A. leave the 2◊4 between the two pours in the concrete or B. Pull it out once you are done screeding the concrete and fill it in with concrete.
tjcj is offline
post #40 of 100 Old 03-17-2013, 05:50 PM Thread Starter
I was just gonna fill it in with concrete later. Itll be a bit before I put the metal roofing on anyway.
I void warranties.
post #41 of 100 Old 03-17-2013, 06:18 PM Thread Starter
Theres a bar going down the sides. The only numbers/letters on it is. N U 13 S 4 in that order.
I void warranties.
post #42 of 100 Old 03-17-2013, 06:35 PM
tjcj
Ok if it looks like this you have 60
tjcj is offline
post #43 of 100 Old 03-18-2013, 10:16 PM Thread Starter
Ezalycasaid
Got the concrete poured today. Picture doing a squat for about 2 hours and sawing you arms and shoulders back and forth. I'm not doing this again. Ill have pics tomorrow. They guessed and quoted me almost an entire yard too much. So I made a half-a#$ ramp. I had the truck at my house for 2.5 hrs. Only charged me 20 bucks more since they showed up 45 minutes late. Also made the truck driver help us do everything.
I void warranties.
post #44 of 100 Old 03-19-2013, 12:22 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
That'l teach em to be late...
I am envious, my work area is dirt and gravel.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #45 of 100 Old 03-19-2013, 01:01 PM Thread Starter
Ezalycasaid
I was so fed up working in rocks and dirt. My jack stands where always questionable on if they would stay put, I was always muddy, I couldn't roll anything, I would work in snow/rain/-20 temperatures, and moving around a 500 lb welder got old QUICK. I was gonna touch another vehicle until I got a good hard flat surface to work on.
I void warranties.
