24 x 20 ft Workover tubing shop build. - JeepForum.com
post #1 of 100 Old 11-11-2012, 08:42 PM Thread Starter
Im wanting to build an A frame metal carport like this one, except 18 wide and with thicker materials. What would be the better/best/overkill material for this 2.5 x 1.5 x .120 wall rectangular tubing, 2.0 x 1.5 x .120 wall rectangular tubing, 2.0 x .120 wall square tubing, or 2.5 x .120 wall square tubing? All hot rolled. http://www.youtube.com/watch?feature...&v=WbBo0I2-cX4
Old build 99 TJ 100wb on 35s and arbs.
New build D60s, 40s etc.
I void warranties.
Ezalycasaid is offline
post #2 of 100 Old 11-12-2012, 07:41 AM
BPJOOP93
Why not just build it out of wood, and cover it with steel?
BPJOOP93 is offline
post #3 of 100 Old 11-12-2012, 08:19 PM Thread Starter
Ezalycasaid
Wood needs concrete underneath it so it doesnt shift. Also, metals portable, so I can take it down, sleeve it and move it when we sell our house. The metal one I can easily extend out and make the caport longer. Plus the wood one would be more expensive with all the truss Id have to make. I can make the entire 20x18 carport for $800. The wood one is 800 without sidding and truss, then id be in the wood one another $1400 for concrete.
I void warranties.
post #4 of 100 Old 11-13-2012, 10:24 PM Thread Starter
Ezalycasaid
I got 300 feet of 2-3/8 x 3/16 wall for 300 today.I was thinking run 2-1/2 x 1" x 14gauge rectangular tubing as the base so I only have to notch the top of the legs. Is 2-1/2 x 1" x 14 gauge rectangular hrew tubing stronger enough to take the weight and not bend with that heavy of round tubing, or should I use thicker walled rectangular?
I void warranties.
post #5 of 100 Old 11-14-2012, 06:39 PM
Motorcharge
x2 on wood. Steel tube is total overkill.
You can frame it with wood studs for significantly cheaper and you can use treated lumber for the bottom plate on the framing and you don't need a concrete foundation for it if it's framed correctly. 58 foot of wall, you're only looking at about $190 to frame the walls. You could do one in wood for under $500 easily.
Slap some OSB on the inside and outside, throw in some insulation, tyvek, and cheap siding and you'll have a significantly better structure for far less time, money, and effort.
Even if you want to go with metal you're far better off doing it with metal studs.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #6 of 100 Old 11-14-2012, 09:51 PM Thread Starter
Right now OSB is about 26 bucks a sheet at the cheapest out here. Thats 200 per wall if done inside and out. The actuall frame/walls 2x4s wouldnt be bad with wood, but not moveable. Another issue is designing and building the truss for wood frame roof that will span 18'. Theres a decent amount of money in the truss. Im actually gonna use wood 2x4s as purlins. Id also have to figure out how to put the truss on top of walls after there built, with the way Im wanting to build this Ill build the frame and roof together and then stand it up on the base and weld them in place. That way I only need someones help for one day.
I void warranties.
post #7 of 100 Old 11-15-2012, 04:26 PM
Motorcharge
Good god, where are you looking at OSB at? It's under $10 a sheet here...
|SOLD|
| June 2015 COTM |
post #8 of 100 Old 11-15-2012, 10:49 PM Thread Starter
Thats what it was before that storm down south, but then it jumped to 22 a sheet, then with the Storm that hit the NE now its 26 a sheet here. (Priced at true value, lowes, home depot, sutherlands and 84 lumber.) I thought about wood 2x4s and osb a while back but then priced everything and backed out of it. The main reason for me going with the huge tubing is because it was only 1dollar a foot and can hold up to some SERIOUS force. Just for my particular situation tubing was cheaper. Its also cheaper for me to sleeve 2-7/8s over it for 1.50 a foot. If I wanna move it later.
I void warranties.
post #9 of 100 Old 11-19-2012, 05:38 AM
mylittlecj5
1974 CJ5
About 3 years ago I had a 18x21 carport with 8 foot sides (1 foot taller than normal) installed at my house for a total of $700. Then add your choice of materials to enclose it. I did mine with a 4' lean-to on one side and a 6' lean-to off the back for a little more room and I only had about $1800 all told with electrical and everything. Flat sides would be considerably cheaper.
Took the whole thing down when we moved and set it up at the new house (without the lean-tos this time).
Default Jeepers Club #10
mylittlecj5 is offline
post #10 of 100 Old 11-30-2012, 03:27 PM Thread Starter
Ezalycasaid
Ok so I got some actual numbers. Its going to be 19ft wide by 20ft long, by 7-1/2ft tall at the sides and 12ft tall at the peek. Made some tube gussets at the top or trusses if u will, 3ft long and sides 2ft long. It took me 13hrs but I hand notched 80 notches, made 80 cuts, and so far welded a 1/4 of them. Using a chop saw, grinder and cutoff wheel. They could probably just have supported themselves without the tube gussets but I like overkill. I still have to buy and burry some railroad ties and leave them sticking out 2"s.Then buy some 3/8" x 3" wide steel plate as the base to put on top of the railroad ties.Screw them down to the railroad ties. From there I still have to cut 4ft tube lengths and use them to tie the frame pieces together laterally. Then Ill put some 2x4x20ft long wooden studs to anchor the metal roofing to running laterally on top of the frame. Anyway heres some pics of the progress. First pic is of the top eve gussets, second is of the sides (I know that one of the side notches arent welded, however the bottom side of it is, and that side will be welded tomorow), and third is of the overall size.
I void warranties.
post #11 of 100 Old 02-18-2013, 10:24 PM Thread Starter
Ezalycasaid
Been a while since Ive posted on here. Heres the progress. Ive been really slow with the build due to tax's, and not working alot.
I void warranties.
post #12 of 100 Old 02-21-2013, 05:51 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Make sure to run diagonal bracing From the ends to keep the sheer loads imposed by the wind from pushing it over.
Other than that lookin great! I has a jealous...
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #13 of 100 Old 02-21-2013, 06:26 PM
Motorcharge
Looking good.
And GOD DAMN that is one crunchy XJ.
|SOLD|
| June 2015 COTM |
post #14 of 100 Old 02-27-2013, 09:12 PM Thread Starter
Ezalycasaid
Looking good.
Thanks. Lol its a toyota four runner. And yes its a cherry one owner mall crawler.
I void warranties.
post #15 of 100 Old 02-27-2013, 09:15 PM Thread Starter
Will do. I will also pour a concrete slab with the piers in the slab, and with rebar going through the concrete piers I have down now. Itll be pretty anchored down. Ill rebar the concrete slab every 2ft, and Im useing 4"s of 4000psi mix. Should be plenty strong.
I void warranties.
