2011 Jeep Liberty Rebuild - JeepForum.com
post #1 of 13 Old 01-24-2014, 01:31 PM Thread Starter
hockeycns
Hey all,
I am a new member to this forum. I am also new to jeeps. I bought a 2011 Jeep Liberty Limited Edition that went through a stone wall with the point of impact being the front drivers side. As you can see from the pictures the wheel looks pretty bad.
When I got it to my house I took that wheel off and put the full sized spare on and the jeep actually drove! When I took a sharp turn out of my driveway I felt the tire rub and when I looked at it the wheel was pushed more towards the rear-end of the car then the passenger side wheel (which has no damage).
I took the wheels off both sides and started comparing but I do not see much wrong with it which I think is a good thing unless that means its a bent frame. I posted some pictures of inside the wheel well and also of the front end cross member. It looks like the sway bar is too close to the lower control arm? Any input would be helpful!
Thanks,
Chris
hockeycns is offline
post #2 of 13 Old 01-24-2014, 02:51 PM
222Doc
222Doc's Avatar
not sure what you want? i mean the pics help little. i can say it wont be cheep and there will be much to replace. IFS when hit can get rather expensive rather fast/ If you can do the work its just parts. Did the airbags go off? These systems have many related parts to fix as well. One reason cars get totaled out is the cost of getting the systems right do to liability issues on top of body repair.
you have good mechanical skills? tools a place to strip it down?
222Doc is online now
post #3 of 13 Old 01-24-2014, 03:40 PM Thread Starter
hockeycns
Thanks for the reply, the airbags did not go off. I found a salvaged 2008 jeep liberty black for most if not all of the body parts and when I looked at it again it looks like everything is in working condition except the front crossmember might be pushed in at the bottom causing it to be slanted. The reason for my post was if someone saw something in the pictures that I didn't notice it would save me some time.
I have taken apart trucks mainly (IFS) so it is very similar and I do have places to go and air tools
post #4 of 13 Old 01-24-2014, 10:11 PM
AtTheHelm
Its hard to tell from the pics but I do suspect the cradle was pushed in. Hope you got it real cheap, it looks like its going to be pretty expensive to bring it back esp considering all the panels that got hit.
AtTheHelm is offline
post #5 of 13 Old 01-24-2014, 10:12 PM
AtTheHelm
Its also a unibody, no frame..
post #6 of 13 Old 01-25-2014, 12:17 PM Thread Starter
hockeycns
Yes I got it for $4000 and I realized after I said that it didn't have a separate frame and body. I've got a body guy coming over today and will post the results for anyone's curiosity. It's also going on a lift Monday morning to better assess the damage but if the cradle is the only issue wig suspension I would be satisfied. It only had 35k on it and runs great so I'm optimistic I will be able to get this looking and driving like it was before the crash
post #7 of 13 Old 01-25-2014, 02:46 PM
AtTheHelm
I wish you luck! 4k doesn't sound bad, hopefully you're not in the red after repairs. Are you keeping it or fixing and selling? This might be a good chance to upgrade the suspension and do custom bumpers. I drive a 2010 KK and its been a great vehicle the 3 years I've had it.
post #8 of 13 Old 01-25-2014, 05:26 PM Thread Starter
hockeycns
Nice jeep! I'm at least going to drive it until the summer and then I decide whether to go back to a diesel truck or keep this. What do you have on your keep as far as suspension?
post #9 of 13 Old 01-25-2014, 05:29 PM Thread Starter
hockeycns
Also I had my body guy take a look at the jeep and it will be $2500 in parts, paint, and labor for the jeep. I will be speaking to my suspension guy to confirm my thought of a bent front cross member and make sure everything else checks out.
post #10 of 13 Old 01-25-2014, 06:03 PM
AtTheHelm
Thanks
I'm running Old Man Emu HD springs, Bilstein shocks, and Jeepinbyal upper control arms. Rides so much better than stock.
post #11 of 13 Old 02-03-2014, 03:01 PM
takeitsleazy
wow, 4k for the jeep and 2.5k for repair? I say thats absolutely worth it. Even modded, it wont tackle all trails, but it can definitely be modded to have some good fun. Nice buy
2013 JK 2DR 3.6L, 1991 XJ 4DR 4.0L, Wife:2008 JK 4DR 3.8L
takeitsleazy is offline
post #12 of 13 Old 02-13-2014, 12:05 PM Thread Starter
hockeycns
NEED HELP!!
I've got the jeep almost all fixed up. Just getting the last few cosmetic parts and new spare. One part that I cannot find at all is the OEM drivers side Rocker Panel (the plastic piece that runs below the doors from front to back).
Can anyone help with this??
Thanks,
Chris
post #13 of 13 Old 02-13-2014, 06:55 PM
AtTheHelm
Dang, I had the full kk parts list for EVERYTHING along with diagrams but lost it.
