2"x2"x1/8" tubing for carrier - JeepForum.com
post #1 of 16 Old 07-19-2010, 06:44 AM Thread Starter
squigy123
hello all
im having trouble getting 3/16" square tubing for my swing out on the tire carrier. for up to a 35" tire do you think 1/8" would ok if i gusset at tall the joints?
squigy123 is offline
post #2 of 16 Old 07-19-2010, 07:23 AM
KMD
1976 CJ7
Seems a little thin to me. Hold out for the thicker stuff. Have you tried a scrap yard?
KMD is offline
post #3 of 16 Old 07-19-2010, 07:41 AM Thread Starter
squigy123
yea ive been searching around every week for a few months. i can get it but i need to order at least 2 24 foot sticks. and i definitely wouldnt be using that much.
post #4 of 16 Old 07-19-2010, 07:48 AM Thread Starter
squigy123
got lucky and found some. i have to buy 24' stick though. gonna have to get it cut down so i can stick out the back of my jeep lol. or let it drag down the interstate. its a 20 mile drive to go get it.
post #5 of 16 Old 07-19-2010, 09:09 AM
jpony645
What about 1/4" wall? I can easily find the 2"x1/4" wall stuff in the drop yard at my local place. Better to have more than not enough. I'm not sure I'd even use 3/16 wall if you're gonna be carrying a 35. My bumper is made from 3/16 and the carrier is 1/4. The bumper flexed where the spindle was welded in until I got Zach's mega spindle that went all the way though my 5" bumper.
jpony645 is offline
post #6 of 16 Old 07-19-2010, 11:50 AM Thread Starter
squigy123
well my bumper is 2" x 4" x 1/4" and my spindle goes all the way through. i think i would have been ok with a gusseted 1/8" carrier but 3/16" is definitely enough. that seems to be the material used on most aftermarket bumpers.
post #7 of 16 Old 07-19-2010, 11:59 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
1/4" wall for the carrier is overkill. You want to save on weight whenever possible. 3/16" works just fine when designed right.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 16 Old 07-19-2010, 12:33 PM
ImpactFabWorks
IMO 1/4" is a bit ridiculous for a tire carrier. I have a buddy than ran his 40" spare on our tire carrier and it is made with 3/16", No flexing and no problems
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #9 of 16 Old 07-19-2010, 01:07 PM
DannyRoark89
1995 XJ Cherokee
i have had 35's on the ones i have built with.120 wall which is 1/8" but its round tubing not square with no negative impacts on its structural integrity. just my 2 cents
rusty is right you dont want a 200 lb bumper with another 70 lbs of tire
DannyRoark89 is offline
post #10 of 16 Old 07-19-2010, 01:37 PM Thread Starter
squigy123
is a to z fabrication out of business? there website is down.
post #11 of 16 Old 07-19-2010, 03:33 PM
rustywrangler
works for me: AtoZ Fabrication...Made In the USA
post #12 of 16 Old 07-22-2010, 10:09 PM
NEVADAGARY
Don't use 2x2x1/8 wall you'll be sorry. I did and it twisted and wobbled all over the place. I rebuilt my hitch mount tire carrier using 2x2x1/4 and it is the cat's meow. Definitley not overkill or too heavy...IF YOU USE THE RIGHT PIVOT AXLE! I used a 3/4-10 grade 8 bolt on my first one and it was a nightmare opening and closing it. I have a great solution but I have to become a vendor before I can offer it.
Gary D.
Old but having fun
Real Americans drive Real American!
NEVADAGARY is offline
post #13 of 16 Old 07-23-2010, 06:46 AM
Area.3.Fiftyone
IMO if you design it correctly and gusset it, it should be fine.
The key is to triangulate the assembly and add gussets where needed. 3/16" would be better, but if 1/8" is all you have then by all means use it.
I would not design it so that the bottom hinged section is the only thing holding it up though. If you could use at least 2 pieces that tie into the hinge point, I think you would be fine.
Do you understand what I'm trying to say regarding the main hinged arm?
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #14 of 16 Old 07-23-2010, 02:48 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've built quite a few rear bumper/carriers using 2"x3"x1/8" for the main swingarm and 2"x2"x1/8" for the center upright and "A" frame pieces..
The 2x3 resists twisting at the pivot tube alot better than the 2x2 square tube.. I think it also looks a little more "proportional".
I run a 35" spare with steel rim on my own CJ and know of at least a few guys running up to 38" rubber on my carriers with that 1/8" wall swingarm.
BESRK is offline
post #15 of 16 Old 07-23-2010, 03:13 PM
NEVADAGARY
And that was the problem with my first tire carrier made entirely out of 2X2X1/8 tubing. The swing arm twisted. I still use the uprights on my new one. They work fine.
Gary D.
Old but having fun
1/4 , 1/8 , 3/16 , tire carrier , tubing
Fold "down" spare tire carrier Floridazed Fabrication Shop 37 03-27-2011 07:51 PM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty Audio, CB & Ham Radios, GPS, & Electrical 6 03-05-2010 07:27 AM
Need Help Deciding on Powertax "No-Slip" or full carrier Detroit 1badxj General Jeep & Off-Road Equipment 3 03-15-2009 10:32 AM
Dana "slow" carrier? BillR General Jeep & Off-Road Equipment 3 01-25-2003 09:35 PM
"Posi" carrier vs "Open" in Dana 35? Big92Jeep General Jeep & Off-Road Equipment 6 11-18-2001 03:24 PM
