2-door XJ Pillar Vents - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > 2-door XJ Pillar Vents
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 04-05-2015, 08:36 AM   #1
mschi772
1997 XJ Cherokee
I have this wild idea of installing vents into the pillars behind the quarter windows. Some 2-doors had vent windows, but they were right behind the front seats. My dogs often ride all the way in the back, and to allow air to flow all the way to the rear of the vehicle would be awesome. Plus, the slightly vent-looking moldings that were used here could actually have a function.
I have absolutely no idea how to make this a reality, however. They'd have to open and close, and seal tightly enough when closed not to be noisy/leaky. With the XJ being a unibody/uniframe, I'm also not sure if such a modification would affect structural integrity or not.
Any help or brainstorming would be much appreciated.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 11:21 PM   #2
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Structural questions aside, this is still going to be a challenging project. You'll have to breech 3 solid layers, the 'vent' trim on the outside, the sheet metal behind it, and the plastic trim on the inside. Then you'll need to fit all three with ductwork and seals and also come up with a weathertight means to close them off when needed.
It would have been cool though if Jeep had set us up with working rear quarter vents from the factory.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
chris87xj is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 04:50 PM   #3
mschi772
1997 XJ Cherokee
Two other ideas have been a vent in the roof like a sunroof but not as long/wide and wouldn't have to be glass--just something to pop open. Or modding the quarter windows to pop open at the back as a whole kinda like Caravan's have.
Sent from my phone.
