1991 YJ rear seat belt bolt - cant remove - JeepForum.com
post #1 of 12 Old 09-26-2010, 10:05 PM Thread Starter
BRI-NYG
I decided to replace the rear fold and tumble bench seat in my 1991 YJ. The bold holding the belt harness to the floor behind the seat would not come loose. It is a Torx bolt and it became stripped. I tried a hacksaw to create a square angle to get a pair of vice grips on it, but that did not work. I took it to a shop, they said they could remove it but wound up cutting it off. What is left of the bolt is still sticking up about 1/4 inch, so now I cannot even re-attach the lap belt assembly.
Any suggestions on how to get this bolt out?
Also any idea what the rear fold and tumble seat is work in reasonable decent shape?
BRI-NYG is offline
post #2 of 12 Old 09-26-2010, 10:07 PM
g4x4xgeoff
you're saying some of the stud is left sticking out of the floor?
Your best bet is to drill it out, then get a nut and bolt and reinstall that way.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #3 of 12 Old 09-26-2010, 10:12 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
THIS IS A BIG FYI TO THE OP, WARNING!!!!!!!!!!!!
Directly under that bolt is the gas tank so please take proper precautions if you end up drilling.
That being said, if you have 1/4" sticking out then get a nut that fits over it and get it welded on. preferably a large nut say a 3/4" head on it.
If you can't do that, then I would advise dropping the tank and then drilling the bolt out.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 12 Old 09-26-2010, 10:17 PM
g4x4xgeoff
Rusty,
Are you 100% on that? the bolt in question is directly above my differential.
post #5 of 12 Old 09-26-2010, 10:34 PM
rustywrangler
Originally Posted by g4x4xgeoff View Post
Rusty,
Trying to do the math in my head here. I thought the ones in front of the diff were the front seat bolts and the rear bolts were above the tank but now that I think about it, they may be on a strip right in front of the skid plate mount bracket.
post #6 of 12 Old 09-26-2010, 10:38 PM
teamgreen666
heat the bolt head up with a small torch and then try and get it out from the top or the bottom of the jeep as it sticks out.
teamgreen666 is offline
post #7 of 12 Old 09-29-2010, 08:24 AM
YJhobby
Are you planning on replacing the rear seat with a new one, or are you removing it for good? If you're replacing it, you need to use PB blaster and rustywrangler's welded nut method, it should work more easily than drilling that big bolt out & potentially messing up your threads.
If you are not putting a rear seat in it, why not just grind it flush and be done with it?
~Steve~
Originally Posted by SnowdogMarc
YJ's don't get stuck....they get temporarily impeeded in their forward progress.
I'm patiently waiting for the "foot-in-mouth" moment to end... but since I've posted, its not today
YJhobby is offline
post #8 of 12 Old 09-29-2010, 03:14 PM Thread Starter
BRI-NYG
Thanks to all who have replied to this thread. Yes, I am planning to put in a new rear seat. I purchased one with headrests, because I want to protect my kids against whiplash. The seat I purchased came with a bracket that mounts over the bolt holes for the existing fold & tumble bench seat. The front bolts, two on each side, came out fine. The bolt holding down the rear bracket mount, along with the lap belt mount, was stripped when I tried to remove it.
I have been told that this bolt is directly over the gas tank. I did not think about the rear differential. I like the idea of welding a bolt head to the part of the bolt that is sticking out, but that seems rather permanent.
Ideally I would like to have it drilled out and insert a new bolt. I welcome further thoughts on this.
And if anyone has a sense of what a decent OEM rear fold & tumble seat is worth I'd love to know. I am going to sell the one I just took out of the 1991 YJ.
BRI-NYG is offline
post #9 of 12 Old 09-29-2010, 03:17 PM
g4x4xgeoff
i sold mine for 75 bucks
post #10 of 12 Old 09-29-2010, 03:19 PM
rustywrangler
I think you got the welding part wrong. You weld a big nut on the top of the existing portion of the bolt and then use that big nut to back out the remainder of the bolt, now insert a new bolt.
post #11 of 12 Old 09-29-2010, 03:21 PM Thread Starter
BRI-NYG
g4x4xgeoff, thank you for the price info. I was think around $50, mine is in pretty decent shape. I appreciate the reply. Thank you and happy Jeeping!
BRI-NYG is offline
post #12 of 12 Old 09-29-2010, 03:23 PM Thread Starter
BRI-NYG
Rusty Wrangler, thank you for the clarification, that makes sense. Me = dense today. Thank you!
BRI-NYG is offline
Amp under rear seat-how to bolt/velcro? CCJ Audio, CB & Ham Radios, GPS, & Electrical 30 04-17-2009 09:58 AM
ahh moved the do not remove bolt!!! tallrugbyguy Engines & Drivetrain 0 03-05-2009 02:15 PM
xj seat belt jeepian General Jeep & Off-Road Equipment 2 11-19-2008 09:30 PM
how to remove serpentine belt emt8c Engines & Drivetrain 1 10-07-2006 01:26 PM
Making bracketry to bolt a front CJ seat in the rear... Tacoma750 Fabrication Shop 1 03-12-2006 05:11 PM
