110 welder - JeepForum.com
post #1 of 12 Old 05-02-2017, 08:49 PM Thread Starter
Bearcub1985
110 welder
I am looking to get an entry level welder. I don't have 220 in my pole barn so will be just looking at 110 models.
I was thinking about the Lincoln handy mig I think it is called runs about $350 new. Can run gas or gas less.
I found a craftsman mig welder with the tank on Craigslist and they are asking $$250 for the set up.
The Lincoln seems to have good reviews anybody have any thoughts?
Also how much does a tank usually cost?
Thanks.
Bearcub1985 is offline
post #2 of 12 Old 05-02-2017, 08:58 PM
Topher11
Topher11's Avatar
Also look at Hobart. Buy the tank outright, don't rent it. A bottle will run you anywhere from like $150 for a 40CF up to $250 for an 80CF to buy including the first fill. Just depends how much u plan to weld and how many trips you want to make to the gas store. 20CF will last you about an hour+ of weld time depending on your flow rate.
1999 WJ 4.0/6"/CLAs/33s/242SYE/ZJ Rad Swap
2006 LJ 4.0/2.5"/33s
Respected Access Is Open Access. Tread Lightly.
Topher11 is offline
post #3 of 12 Old 05-03-2017, 08:13 AM Thread Starter
Bearcub1985
Thanks, will check out the Hobarts. Any one have any experience with a sears?
post #4 of 12 Old 05-03-2017, 07:45 PM
u2slow
2005 KJ Liberty
I would look at one of the slightly larger 120/240 dual voltage machines. I'm 8 years in with my MM211... started out with only 120v, but now I have 240v in my shop.
2005 KJ V6/6spd/3.54 posi, No-Slip locker (front), 3" lift.. and some Dodges w/cummins
u2slow is offline
post #5 of 12 Old 06-05-2017, 08:11 AM
sajigore
+1 on the Hobart, its nice having both 110 and 220 in one unit JIC you get an outlet later down the road.
sajigore is offline
post #6 of 12 Old 06-05-2017, 11:19 AM Thread Starter
Bearcub1985
Thanks. What price range would a decent MIG with both the 110 and 220 capacity be in?
post #7 of 12 Old 06-05-2017, 11:54 AM
sajigore
Friend just bought The hobart 210MVP and really likes it ~$800
my Lincoln 110 almost cost that 10 years ago.
sajigore is offline
post #8 of 12 Old 06-05-2017, 03:39 PM
emcee5000
emcee5000's Avatar
Hobart 210 MVP is a great entry level machine, have it, love it wish I had bought it sooner. Bought the HF 90amp flux to get into welding which was cool to get started but in the end a waste of money. Get the MVP, get a tank, get 220 in your garage/workshop in that order. I thought flux was good until I went to gas/solid wire, it does make a big difference. Going 110 to 220 was also a big step but glad I did. I can weld at home and at a friends house if required with the MVP. Do it right, do it once.
emcee5000 is offline
post #9 of 12 Old 06-05-2017, 04:16 PM
-OIIIIIIIO-01
Mall Rated
-OIIIIIIIO-01's Avatar
I second this as well. I bought my 1st welder this year, and after much research I too chose the Hobart 210MVP.
Great machine to start with, and the Lincoln and miller comparable are a few hundred more price wise. I paid $850 f/TSC.
91 YJ 4.0/AX15/231J AA SYE/ Tom Woods CV
3.5" BDS Springs / .75" Booms / 1"BL
HP D30 /Akebono's /1 Ton GM Crossover Steering
Ford 8.8 / Trac loc LSD w/ disc brakes
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
-OIIIIIIIO-01 is offline
post #10 of 12 Old 06-21-2017, 09:44 PM
holliewood61
1981 CJ7
I have a lincoln weld pak 100hd and a hobart handler 190. I find myself using the lincoln a lot more. No bottle to fuss with, i have 110 outlets all over my garage and only 2 220 outlets, and i have a super heavy extension cord for the 110 that i can run out to the driveway if need be. The only time i really use the hobart is if im working with .250" or thicker.
holliewood61 is offline
post #11 of 12 Old 08-20-2017, 12:55 AM
K9kodi
I would say if you get a welder now and plan to do a lot, get one with 110/220 power. If you get into it you may want to up the power. I just got an esab cadymig and that thing is a work of art!
K9kodi is offline
post #12 of 12 Old 08-27-2017, 07:00 PM Thread Starter
Bearcub1985
Thanks for all the input. Still saving up some money to get one. I like all the feedback I have looked a little more and there are a lot of options. I am also suprised on how expensive they can get.
