100 amp arc welder enough - JeepForum.com
post #1 of 8 Old 07-29-2004, 07:10 PM Thread Starter
penguinland
penguinland's Avatar
Is a 100 amp arc welder enough to weld up 3/16 plate for skids etc and for putting mounts onto an axle ? The last time I welded was in high school and those were some big old beasts. I hope it all comes back to me Any suggestions on which brand and where to get one, new or used
2004 WJ 4.0
2" BDS springs + 3/4" spacers up front , Goodyear Duratrac 245/75R16, Yaesu FT-7900R
penguinland is offline
post #2 of 8 Old 07-30-2004, 12:17 AM
ScotZ
American to the Bone
ScotZ's Avatar
If you are just welding mild steel plate. You should be fine. The old Lincoln 225 AC "buzzbox" is a great little stick welder. You can pick them up at auctions for between $50 and $100 bucks . They sell for a little over $300 new.
At least two-thirds of our miseries spring from human stupidity, human malice and those great motivators and justifiers of malice and stupidity: idealism, dogmatism and proselytizing zeal on behalf of religous or political ideas.
- Aldous Huxley
ScotZ is offline
post #3 of 8 Old 07-30-2004, 05:01 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If you're looking strictly for a stick welder, I picked up a Lincoln 225 amp at Lowe's for like $199 when it was on sale. Normally, I think it's about $229 or so. I don't think I'd hit axle tubes with a 100 amp welder... I don't think you'd get enough penetration.
BESRK is offline
post #4 of 8 Old 07-31-2004, 04:51 AM Thread Starter
penguinland
Would the 225 amp lincoln be enough for the axle ? What kind of power supply line would I need to power a 225amp welder? 220v or 110v and what amperage breaker ? Thanks
2004 WJ 4.0
post #5 of 8 Old 08-01-2004, 06:21 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You'd need 220v and a 50 amp breaker (if I remember correctly).
BESRK is offline
post #6 of 8 Old 08-14-2004, 06:37 AM Thread Starter
penguinland
I'm going to get at least a 225 amp arc welder. Does anyone have one of these? Or am I better off going with the Lincoln 225 AC that Lowes carries?
http://www.mytscstore.com/detail.asp...productID=9544
2004 WJ 4.0
post #7 of 8 Old 08-14-2004, 09:39 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hobart, Lincoln or Miller are all well-made welders.. I just picked up the Lincoln because it was in stock at Lowe's (got it on sale for $199).
BESRK is offline
post #8 of 8 Old 08-15-2004, 12:35 PM
rickr
ac/dc
don,t waist your money on an ac stick welder
rickr is offline
Got a new welder Tomb Raider Fabrication Shop 2 02-23-2006 07:26 AM
Which Welder for what i want to do? jnkyrdg04 Fabrication Shop 12 02-21-2006 07:51 PM
i need a welder Texas TJ Fabrication Shop 33 02-14-2006 11:22 PM
Looking to buy a welder.... NEWtoTHEjeepLIF Fabrication Shop 2 12-31-2005 10:46 PM
welder 79cj5Dr Fabrication Shop 7 12-29-2005 08:14 PM
