is 1/8" for the corners of my front bumper too thin - JeepForum.com
post #1 of 23 Old 03-19-2013, 11:35 AM Thread Starter
sevenscrew
I'm constructing a Zj bumper, the center section(below grille/mounting and all) is made of 1/4" thick
would 1/8" be too thin to finish the bumper in? below the headlights all the way around the corner of the fender would be 1/8" if i use it.
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #2 of 23 Old 03-19-2013, 11:47 AM Thread Starter
sevenscrew
There's the center
2016 2DR JK
post #3 of 23 Old 03-19-2013, 01:47 PM
paintballwannab
1/8" will be fine, we've done entire bumpers from 1/8, other then the winch plate and mounting points.
paintballwannab is offline
post #4 of 23 Old 03-19-2013, 02:04 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
You will want to reinforce it internally. 1/8" is a great alternative for those that do mild wheeling on 1 and ocassional 2 rated trails. Light bumping of trees and such. If you plan on hitting anything with a good clip 3 and up rated trails...sliding off rocks or muddy trails that push you hard into trees....you'll want 3/16". Unfortunately...only you can determine the level of your offroad adventures
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #5 of 23 Old 03-19-2013, 02:13 PM Thread Starter
sevenscrew
It wont be serious hits, if any, i dont go fast when i offroad i do everything slow. and we dont have real big rocks to fall on to. What do you mean reinforce it internally? gussets out of 1/8"?
2016 2DR JK
post #6 of 23 Old 03-19-2013, 04:22 PM Thread Starter
sevenscrew
Pics of my mockup
All the pieces x2(for other side) fit in a 2x4 frame so I can use 2x4' of 1/8" it'll be about 30 something bucks
image-626880589.jpg   image-920470595.jpg   image-2119970314.jpg   image-512720058.jpg   image-1313519605.jpg
2016 2DR JK
post #7 of 23 Old 03-19-2013, 05:51 PM
riot1987
Id tuck that EVAP canister in there a bit better. Just my 2 pennies worth
Build thread^^
riot1987 is offline
post #8 of 23 Old 03-19-2013, 05:52 PM
riot1987
I mounted mine Horizontal and it tucked in there real nice like
Build thread^^
riot1987 is offline
post #9 of 23 Old 03-19-2013, 05:57 PM Thread Starter
sevenscrew
On my list of things to do! Haha thanks for reminding me tho
2016 2DR JK
post #10 of 23 Old 03-19-2013, 06:18 PM
riot1987
I would run 3/16.
Build thread^^
riot1987 is offline
post #11 of 23 Old 03-19-2013, 06:46 PM Thread Starter
sevenscrew
3/16 4x4' was like 88 ish, so 2x4 should only be 44,
1/8 4x4 was like 65 so 2x4 would only be 32.50
for 10 more i probably will go with 3/16th
2016 2DR JK
post #12 of 23 Old 03-19-2013, 07:12 PM
riot1987
You dont need too much to finish out those corners. I think youd be happier with 3/16. Itd be worth the 10-15$ difference
Build thread^^
riot1987 is offline
post #13 of 23 Old 03-19-2013, 07:33 PM Thread Starter
sevenscrew
sorry was doing math in the post lmao. I accidentally calculated 4x4 feet needed to complete it. but it turns out i can fit the cut outs on 2x3-2x4 feet (1 foot will be extra). the place is 45 minutes away so i dont want to go back twice.
2016 2DR JK
post #14 of 23 Old 03-19-2013, 07:39 PM
riot1987
If you mount a winch I would use something heavier for the winch mounting plate. I used 5/16 for mine
Build thread^^
riot1987 is offline
post #15 of 23 Old 03-19-2013, 07:53 PM Thread Starter
sevenscrew
The center section is all done already I used 1/4" for the center
2016 2DR JK
