1/4" plate vs 1/4" flat bar? - JeepForum.com
post #1 of 10 Old 11-17-2008, 10:01 AM Thread Starter
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
Is there any difference between 1/4" plate and 1/4" flat bar? I'm pricing some material for my XJ (bumper brackets, winch plate, etc.) and the guy at the metal store said I'd be better off getting the flat bar. It's definitely a cheaper route and it comes in width's from 2" to 12" so I could get what I need - I'm just curious if it's any different than plate?
Thanks.
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #2 of 10 Old 11-17-2008, 10:39 AM
tweba99
tweba99's Avatar
No, there is no difference. Flat bar is what I used to build my rear bumper since it came in the widths I needed and I only had to make the vertical length cuts that I needed.
1999 Jeep TJ on 1 tons (OLDER)
2003 Jeep Rubicon (OLD)
2008 Jeep Unlimited X (NEW)
tweba99 is offline
post #3 of 10 Old 11-17-2008, 10:44 AM Thread Starter
ChiliPalmer
Awesome thanks and that's what I was thinking about - only having to make one cut!
Forum!
post #4 of 10 Old 11-17-2008, 06:04 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Only downside to using flat bar instead of plate would be the "mill scale" on the HR flat bar.. easy enough to clean off though.
BESRK is offline
post #5 of 10 Old 11-17-2008, 07:55 PM Thread Starter
ChiliPalmer
Ah - that's what that is. I wasn't sure if it was different material because of that. I've got some 2" flat bar sitting in my garage and I knew it was different than plate - now I know why.
Thanks...
Forum!
post #6 of 10 Old 11-18-2008, 02:41 PM
Dlongj
To be extremely honest right now. All Flat/Plate 1/4" Mild Steel comes with millscale. I am currently a Welder in a shop and the only way it comes off is with a grinder unless! you get cold rolled which is little spendy
Dlongj is offline
post #7 of 10 Old 11-18-2008, 05:26 PM
raskull
raskull's Avatar
True, but the millscale on flat bar seems to be thicker for some reason.. it flakes all over when you form it.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #8 of 10 Old 11-19-2008, 03:25 PM
Dlongj
That is also true. It does tend to flake when you heat, bend, or roll it. But in reality it doesnt hurt much. Just grind her down with a soft pad 40/60 grit works great and then paint her up.
Dlongj is offline
post #9 of 10 Old 11-19-2008, 03:31 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If I'm working with small pieces of hot rolled stuff, I toss it in a bucket with a Muriatic Acid/Water mixture for an hour or two. Pull the pieces out, rinse them off and most of the mill scale will wipe right off.
BESRK is offline
post #10 of 10 Old 11-19-2008, 03:39 PM
Dlongj
That also would be great. A little time consuming i would have to say.
Dlongj is offline
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty Audio, CB & Ham Radios, GPS, & Electrical 6 03-05-2010 07:27 AM
If I get a Flat 32" can I... 442Wrangler General Jeep & Off-Road Equipment 14 01-18-2010 07:47 AM
cutting 1/4" flat stock kercher Fabrication Shop 13 01-31-2009 02:23 PM
GE "High Output" or GE "Cool Blue" headlights? itasor Street Jeep Forum 25 09-24-2007 11:57 AM
Looking for 1/2" Steel Plate (maybe 3/8") Scrambler82 Fabrication Shop 8 06-08-2005 09:30 PM
