Yj stretch with xj springs parts list - JeepForum.com
post #1 of 33 Old 02-06-2012, 10:34 AM Thread Starter
Ripper3494
This thread is a GUIDE, not directions, for me and anyone else that would like to do this mod.
This is a pretty loose list of what youll need assuming you already have extended brake lines, sye and a way to relocate shocks.
The knuckles listed will work if your running a wagoneer dana44 with 6 lugs.
The xj are 55in eye to eye with an offset centerpin that will give you approx. 6in of stretch in front and back, totalling ~12in if you use the stock leaf mounts on the frame
1. Astro van steering box
2. Astro pitman
3. 73-76 dana 44 chevy knuckles
a. Machined, drilled and tapped
4. High steer arms
5. 8 xj rear leaf packs
a. 8 spring clamps
6. Fuel cell
7. Way back shackle hangers
8. Front shackle reversal mounts (if you choose to do a shackle reversal at this point)
9. Driveshaft length mods
10. 4 spring perches
11. 4 shackles
12. 2x4 1/4in wall steel for front crossmember
13. Assorted steel for reinforcement of rear crossmember and front frame extension
14. Antiwrap bar (already made just need to lengthen.
The reason for the 8 leaf packs is that xj leaves are very soft so youll have to mix them together to find what works best for you. Ive read that in the rear adding an extra main leaf and in the front an extra main and second leaf seems to work well
Please let me know if there is anything I need to add
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #2 of 33 Old 02-06-2012, 11:37 AM Thread Starter
Ripper3494
http://www.ruffstuffspecialties.com/catalog/25-HANG.html leaf front hangers
http://www.ruffstuffspecialties.com/catalog/WBHGR.html rear shackle hanger
http://www.ruffstuffspecialties.com/catalog/D44-PERCH.html spring perches
http://www.xtremeterrain.com/trestyl...hfabworks.aspxHigh steer arms
will do more in a bit next class is starting
build thread:
RC vs BDS
post #3 of 33 Old 02-06-2012, 11:48 AM
fratis
fratis's Avatar
are all 73-76 chevy dana 44 knuckles flat tops? im no junkyard expert but i dont think so.
edit: a quick review of mr. ns page seems to suggest that all chevy 44 knuckles from the posted years would be flat tops.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #4 of 33 Old 02-06-2012, 12:17 PM Thread Starter
Ripper3494
Yea according to his page all of them would be
build thread:
RC vs BDS
post #5 of 33 Old 02-06-2012, 09:27 PM
TSEJEEPERS
Front Shackle Reverse mounts? Are you also planning on doing a SRS?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 33 Old 02-06-2012, 10:58 PM Thread Starter
Ripper3494
yea, with this setup since i plan to beat it pretty regularly i dont want to be bending springs, not necessary just something im planning on
build thread:
RC vs BDS
post #7 of 33 Old 02-07-2012, 07:24 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I used...
Ford shock towers to outboard my rears.
C Channel to replace my rear cross member
Stock gas tank where rear seat was
a side note. I got over 12 inches of stretch, many others have reported the same.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #8 of 33 Old 02-07-2012, 10:29 AM Thread Starter
Ripper3494
I used...
thanks ill look into those, by any chance did you measure to see approx how much lift was gained from using the xj springs SOA? i know the yj stock springs will give ~5.5in
build thread:
RC vs BDS
post #9 of 33 Old 02-07-2012, 11:02 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I run them SOA on tons(60/10.25), ?" lift shackles, and bastard packs. So I really can't give you any good info on how much lift I got. Some is from the tube thickness, some from the shackles, some from running almost complete double packs.
The top of my stock roll bar B pillar is 80".
Poke is offline
post #10 of 33 Old 02-07-2012, 11:34 AM Thread Starter
Ripper3494
wow your low, i believe im just above 80 and im SUA with a 4 in lift and 37s
build thread:
RC vs BDS
post #11 of 33 Old 02-07-2012, 11:38 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Yeh. On 40's I look up to people that run 35's when we pass on the trails. I'd like to run 42's and lower my suspension 1 more inch.
Poke is offline
post #12 of 33 Old 02-07-2012, 11:42 AM Thread Starter
Ripper3494
Thats a good thing to aim for, id like to be about my current when im done, are your springs in negative arch on flat ground?
build thread:
RC vs BDS
post #13 of 33 Old 02-07-2012, 11:47 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Not at all. They look somewhere between stock and 1" lift. and they flex!
check here for flex pics and more info on what I did, note the rear crossmember. Strong and stupid simple . http://www.jeepforum.com/forum/f12/j...l#post12054833
Poke is offline
post #14 of 33 Old 02-07-2012, 01:15 PM Thread Starter
Ripper3494
just read through your thread again, i think the only difference i would make to my rig is to mount the hangers a bit higher up on the front and rear crossmembers to drop me down a bit more. during droop does your pinion start to point down due to the non centered pin on the xj springs?
build thread:
RC vs BDS
post #15 of 33 Old 02-07-2012, 01:30 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I have a anti-wrap in the rear. I need one in the front. My front pinion puts my u-joints in danger constantly.
Poke is offline
