YJ AX15 behind CJ 258 - which clutch? - JeepForum.com
post #1 of 2 Old 12-10-2013, 11:30 PM Thread Starter
MomoJeep
1983 CJ8
I putting an AX15 from a 94 Cherokee behind the 258 in an 83 CJ8. Should I use the clutch that matches the '94 AX15 or the clutch that matches the '83 258 engine?
Thanks!
MomoJeep is offline
post #2 of 2 Old 12-27-2013, 05:13 PM
TMLoftis
1978 CJ5
A little late but I'm sure you could use the flywheel and clutch off a 4.0? Or maybe even put the clutch right up to the 258 flywheel.
TMLoftis is offline
