XJ to TJ drive train swap - JeepForum.com
post #1 of 10 Old 04-07-2013, 07:54 AM Thread Starter
zboss86
The engine in my 2001 TJ is knocking. I was considering buying a wrecked XJ for the 4.0 engine. But Id also like to have HP30 out of it and the AW4 tranny.
Anyone know of a reason that couldn't use the 4.0L out of an XJ? Or any particular years I need to look for?
For the HP30, I need a 92-98 model.
Not sure on the engine or tranny, but I'm reading up on it...
Cleaning out the garage... check what I have for sale here:
http://midsouthjeeps.com/forum/index.php?/topic/20693-jeep-parts-for-saletradebumper-2-spacers-relocation-brackets/
zboss86 is offline
post #2 of 10 Old 04-08-2013, 02:27 AM
cavscout187
The 00 to 01 will work. Why not put a v8 in? I did mine for right at 2200 used a 5.9 magnum more power and better fuel econ im getting 18 cty an 23 highway with 35s and 456 gears
cavscout187 is offline
post #3 of 10 Old 04-08-2013, 07:29 AM Thread Starter
zboss86
I am considering using a 5.3 LS style engine with a 4L60E tranny. I'm pretty familiar with the GM drive train. Do you have a write up on your 5.9?
zboss86 is offline
post #4 of 10 Old 04-08-2013, 07:33 AM
cavscout187
No but i got to keep factory gauges no check engine light and kept my 5speed
post #5 of 10 Old 04-08-2013, 07:34 AM
cavscout187
There are alot of write ups
post #6 of 10 Old 04-08-2013, 11:04 AM
RockRodHooligan
RockRodHooligan's Avatar
You sure? The top end is the same, but the blocks are different. TJs had two different blocks, 97-99/00-06, XJs used the same block 96-01, but used two different heads, 96-99/00-01.
It would work, but it's not a bolt in ordeal. WJ engine swap would be more direct.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #7 of 10 Old 04-08-2013, 11:52 AM Thread Starter
zboss86
thx... that's what I was looking for. I was hoping I could use the same short block. GM has spoiled me with the V8 stuff all being interchangeable. My 4.0L engine sounds like a diesel its knocking so loud.
As much as I'd love to do a V8 swap, time is a big factor. I was looking for a quick fix for the 4.0L engine and then have the option of using the HP30 and AW4 later on. But I don't think it's going to be that easy.
I'll keep digging, but it's looking like I need to scrap that idea.
zboss86 is offline
post #8 of 10 Old 04-08-2013, 12:33 PM
cavscout187
I sold my 03 4.0l to a 01 wj also installed fit perfectly only why not get a long block from orielly auto parts 3 year warranty unlimited miles pretty good deal?
post #9 of 10 Old 04-12-2013, 05:35 AM Thread Starter
zboss86
That's not out of the picture... I may do that.
zboss86 is offline
post #10 of 10 Old 04-12-2013, 06:44 AM
cavscout187
Or do a v8 magnum for alittle more
