Wiring Questions - JeepForum.com
post #1 of 7 Old 09-10-2013, 08:38 PM Thread Starter
Long&Low
1967 CJ5
Wiring Questions
Ok, I'm installing a 2.5 ltr MPFI into a CJ5.
I am running into wiring issues with respect to the Jeep providing spark and fuel pump operation. I'm betting its due to not having the wiring straight for the Auto **** Down and fuel pump relay.
Anybody got any info on bypassing the ASD and fuel pump relays?
Engine and harness are out of a '92 Wrangler, the wiring harness for the CJ5 body is an EZWire kit. The engine does crank over, but there is no spark and the fuel pump does not prime/pump.
And yes, the Wrangler did work before I removed it from the other vehicle.
I tried calling Hesco to see if they could put together a 2.5 ltr harness like they do for the 4.0ltr, but that was a no-go.
I'm tempted to send the harness to someplace like Hotwire for them to rebuild. But this really can't be that difficult.
I really don't need the power distribution box from the Wrangler, so is there a way to bypass that, and then provide power to the PCM/ECU?
thanks
Long&Low is offline
post #2 of 7 Old 09-11-2013, 11:23 AM
Xd_shooter676
1947 CJ2A
Y not just make a external relay for asd circuit ?
Xd_shooter676 is offline
post #3 of 7 Old 09-11-2013, 07:08 PM Thread Starter
Long&Low
1967 CJ5
I'd like to do away with the ASD if possible.
Long&Low is offline
post #4 of 7 Old 09-11-2013, 07:09 PM Thread Starter
Long&Low
1967 CJ5
Got the fuel pump to work. After that I called it a night, will check later to see if it fires, or if I'm still not getting a spark.
Long&Low is offline
post #5 of 7 Old 09-12-2013, 01:14 AM
4roadrage
Curious to know how you got it to run and if you used a makeshift relay box.
4roadrage is offline
post #6 of 7 Old 09-12-2013, 06:08 AM Thread Starter
Long&Low
1967 CJ5
Actually, the issue with the fuel pump was a break I the ground wire connection. Something simple.
Long&Low is offline
post #7 of 7 Old 09-19-2013, 07:32 PM Thread Starter
Long&Low
1967 CJ5
OK, so no spark, there are little wires that go to/from the distributor and the coil, where are they supposed to lead to?????
HELP
Long&Low is offline
