Wiring Help - Diagrams incomplete - JeepForum.com
post #1 of 4 Old 10-28-2012, 10:09 AM Thread Starter
shnbrna
1955 M-38
I need some help with the wiring on my system. I am hopeful that some of you who understand wiring will tell me I’m ok, or what to fix.
I am completely ignorant, but dived into this frame off rebuild project anyway - how else do you learn?
I have an M38A1, converted to 12v - still has a generator, generator regulator, original gauges (incl Ammeter), and now a key with separate start button. I have referred to numerous wiring diagrams that solve my individual problems, but not address my whole problem. Would some of you in the know, take a look at my diagram and let me know if I am going to burn my jeep up.
I think I have the lights/taillights and the gauges (other than the ammeter) figured out. It’s the ignition, fuses, etc that are causing me concern.
Thanks for your help,
Shane
shnbrna is offline
post #2 of 4 Old 10-31-2012, 08:50 AM Thread Starter
shnbrna
1955 M-38
New diagram with a fix or two (I think)
I think I missed the mark on a few things. A little more research has gotten me this far.
shnbrna is offline
post #3 of 4 Old 12-15-2012, 02:09 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
did you get answers to your questions.. i know this is old thread, stumbled into it....
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #4 of 4 Old 12-20-2012, 07:43 AM
frhrwa
Fish'n Fool
frhrwa's Avatar
I thought about doing the 6VDC to 12VDC once, figured what I'd do to make it all simpler was... build a 6Volt regulator circuit that would carry the amperage easily.. with a 12VDC input.. the use the output to a fuse panel for 6volt items, and another fuse panel to the 12V input side for all the 12 volt items.. Ground is the same, so I thought that would simplify the operation.. anyway, wound up converting everything to 12v and tossed the 6v stuff.. but that makes more sense to me than resistors and such.. basically the same as a real good batter charger, except on the main transformer it has 12vdc primary's..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
