VSS adapter - JeepForum.com
post #1 of 23 Old 07-19-2013, 05:19 PM Thread Starter
TJNEWBY
VSS adapter
I am just finishing up a 5.3 swap into a 98 tj. I am trying to work through some VSS issues. Does anyone know of a way to adapt a GM 5.3 VSS into a NP231J VSS opening in the transfer case? Getting a GM VSS would make life a lot easier. Also looking at having the PCM reprogrammed to read the Jeep VSS signal. Any thoughts?
TJNEWBY is offline
post #2 of 23 Old 07-20-2013, 07:40 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I kept the Jeep VSS and adapted it to my '02 GM motor with a DakotaDigital.Com adapter unit, but I don't have CAN BUS gauges as is stock in a TJ dash. It may be worth looking into them though, may have something to help.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 23 Old 07-20-2013, 08:50 AM Thread Starter
TJNEWBY
Which product did you use from Dakota Digital? I currently have the SGI 5C but I am getting conflicting info from them if it wiil work or not. Thanks for the reply.
TJNEWBY is offline
post #4 of 23 Old 07-20-2013, 09:39 AM
rckchucker
what are you trying to accomplish? is this for the trans to shift correctly? from what I understand, the GM computer needs a trans input shaft speed, output shaft speed and vehicle speed to shift correctly no? When I did my 5.3, I used a manual, but I needed a speedo so all the emissions junk would work. I believe I used a Dakota Digital SGI-5. I also programmed my GM PCM to look for 3 pulses per revolution since that is what the rubicon tcase tone ring is. When that Hall effect signal is converted to the AC signal the GM PCM understands, my speedo is off by 1 mph at 75 mph. It is pretty close. I retained my factory gauges, so I just teed off the signal wire and ran one up to the gm computer.
rckchucker is offline
post #5 of 23 Old 07-20-2013, 12:43 PM Thread Starter
TJNEWBY
Yes,my main goal is to get the transmission to shift correctly. I currently have the SGI 5C installed but the GM PCM doesn't recognize the signal from the SGI 5C. So one of my options is to send my PCM back to Speartech and have them re program the PCM to recognize the signal from the SGI 5C. Do you know of any issues I might have re programing the GM PCM with the 4L60E transmission?
TJNEWBY is offline
post #6 of 23 Old 07-26-2013, 12:20 PM
DLWRUBI
If the VSS is in the TC, how will it shift right in 4 wheel low unless you have a way to tell the PCM to use your TC ratio in low range? I believe the GM 4x4 trucks had this provision. That's why it's recommended to use the VSS in the trans. What adapter do you have for your transmission to TC? AA sells a kit for adding a VSS to your 4L60E.
DLWRUBI is offline
post #7 of 23 Old 07-26-2013, 03:04 PM
JeeperDon
JeeperDon's Avatar
It's at the output of the TC, the point where each drive shaft revolution means the same thing, regardless of what happens before that point with gears and torque.
Web Admin for
post #8 of 23 Old 07-26-2013, 06:45 PM Thread Starter
TJNEWBY
I would agree with JeeperDon. Everything I have read is that your most accurate reading is at the tail of the T case.Hope to install the reprogrammed ECM tomorrow. Keeping my fingers crossed that it works.
TJNEWBY is offline
post #9 of 23 Old 07-27-2013, 03:10 AM
dg6772
Hey guys, I just completed a cj7 with a tbi 350 and 700R4. I am looking for information on the vss mine will be for the cruise control and whatever else the obd1 system needs it for. Where can I start? Any ideas. Thanks
Dave in Muskegon
dg6772 is offline
post #10 of 23 Old 07-27-2013, 12:14 PM
DLWRUBI
I'm going to have to wrap my head around that, didn'tmean to send any false info, I read this on AA's site:
"Vehicles with a computer controlled engine swap and an automatic transmission requiring a VSS should not use this (transfercase) tailhousing option unless a low range switch is installed and the computer program is modified. When installing this type of engine and automatic transmission combination, we highly recommend a reluctor ring location in the adapter or the transmission. This will give the engine computer system a correct 1-to-1 reading in or out of low range."
Also this is about their true pulse kit where the VSS is behind the yoke of the output shaft. This is the one I'm using and requires a low range switch, which is why they don't recommend it but I have no choice.
"Vehicles with an engine conversion using a 1993 & later GM computer controlled engine and an automatic transmission requiring a VSS “should not” use the True-Pulse VSS kit. When using or installing this specific type of drive train combination, we highly recommend a VSS be located in the transfer case adapteror the automatic transmission. This will give the ECU a correct 1 to 1 reading when in 4wd low range."
DLWRUBI is offline
post #11 of 23 Old 07-28-2013, 11:13 PM
DLWRUBI
Well, did you install the reprogrammed ECM? Does it work right now in both 4 wheel hi and lo? Like to see if your guys logic is correct and I can throw my low range switch in the garbage.
DLWRUBI is offline
post #12 of 23 Old 07-29-2013, 04:39 AM Thread Starter
TJNEWBY
No, I did not get to it this weekend hopefully tonight.
TJNEWBY is offline
post #13 of 23 Old 07-30-2013, 12:21 AM
DLWRUBI
Looks like I found more info. Just makes more since to me with an automatic trans that counts on the VSS accuracy to function properly. If your on the TC tail shaft without a way to tell the PCM you just changed the output ratio by 272:1, 3.8:1, 4:1, or whatever, then how can it shift right with the transmission speed being one thing (what the computer is programmed for) and the TC being another? Below is another quote from a member on here that also did the 5.3/4l60e conversion. Hopefully I'm just being helpful here and not a PITA . I bought a Compushift II transmission controller for a couple reasons, one being it has the wiring provision for a 4 wheel low switch and the ability to program your TC ratio into it. I would have been ahead of the game had I went with a trans output shaft VSS setup since it's always 1:1 no matter what the TC is. My setup will not do a trans VSS though.
"The VSS on the LS series engines is very important with the automatic. Controls shift points, line pressure, and other things. It doesn't just need to know it's moving, it needs to know how fast exactly. That's why when you send your PCM to get programmed, you need to tell the programmer what tire size and gear ratio you are running. Also, the reason why you can't run the VSS behind the transfer case unless you wire in the 4WL switch back to the PCM."
DLWRUBI is offline
post #14 of 23 Old 07-30-2013, 04:28 AM Thread Starter
TJNEWBY
Any info is good info thanks for posting. I think there may be more than one way to get to the results that we need it dependquite a bit on the set up. Hopefully will be putting everything back together tonight to see if my version work. I think I woould have either started with a GM VSS or gone with a non electronic transmission. Hind sight!?
TJNEWBY is offline
post #15 of 23 Old 07-30-2013, 03:36 PM
mattamd_xp
As I've been looking into this for my swap, using a t-case output is very doable. There is a pin on the GM computer than needs to be grounded to tell the computer the t-case is in 4 low and the ratio needs to be programmed in it as well. Pretty easy and a heck of a lot cheaper than AA's adapter/VSS "solution". I've got a np241c with a JB conversions Super Short SYE that has a provision for a stock Chevy VSS that I'm using. I'm just going to program the PCM correctly for the t-case ratio and put a switch on the t-case shifter that will ground the plug on the PCM when I shift into 4 low.
99 Wrangler Project Detroit Mongrel 5.3/4l60e/Atlas HPD60/14B coilovers etc...
mattamd_xp is offline
