Tremec T-150 swap for Borg Warner T-5? - JeepForum.com
post #1 of 5 Old 07-12-2013, 05:08 PM Thread Starter
Lloydster
1976 CJ7
Cj Tremec T-150 swap for Borg Warner T-5?
Will it fit?
'76 CJ7 with 304, Tremec T-150 3 speed and a Dana 20 transfer case.
I want a 5 speed, so I picked up a Borg Warner T-5 out of an '86 CJ7.
Why? Yeah, I know that the T-5 is a weak trans for rock crawling, etc., but my rig is very light duty. I want to increase mileage.
Will the bell housing fit?
How much longer is the T-5? Will my shifter and t-case lever be in a new location?
I realize that I probably need the Dan 300 transfer case. Will it bolt up with little modification?
Another Jeep guy told me that the .86 Overdrive gear would be too high geared, and I'd lose speed on the freeway. He also told me that it'd be really expensive to make the change.
Please provide feedback. Thanks.
Lloydster is offline
post #2 of 5 Old 07-12-2013, 10:37 PM
jp360cj
1977 CJ7
You'll need:
T4/T5 bellhousing for a 258. It will bolt up to the 304.
Dana 300...will bolt on
Skid plate for the T4/T5
New driveshafts
That's all I can think of right now. What gears and tires are you running?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is online now
post #3 of 5 Old 07-17-2013, 12:00 AM Thread Starter
Lloydster
1976 CJ7
Ok, so how can I tell which bell housing is currently on this T-5? I bought it from a guy who got it from another guy, so I don't know what motor it had with it. Is there a way to tell?
post #4 of 5 Old 08-14-2013, 08:43 AM
Fussion4X
if it has a 3 speed bolted to it-it's the wrong one, as simple as that! you need a T4/T5 1980-1986 bell housing. FYI- this is a very bad idea! T5s are very week transmissions.
Fussion4X is offline
post #5 of 5 Old 08-14-2013, 09:47 PM
paveland
If the bellhousing comes to a point at the top it's the correct AMC bolt pattern.
If it is flat and straight on the top, it's the wrong.
Just google image AMC bolt pattern for a picture. It's really obvious once you know what your looking for.
paveland is offline
