Transfer Case Shift Bracket for NV3550 - YJ - JeepForum.com
post #1 of 5 Old 02-01-2013, 11:44 PM Thread Starter
xtrememotives
Yj Transfer Case Shift Bracket for NV3550 - YJ
Just put a NV3550 w/231 transfer case in my YJ. I ordered the transfer case shift bracket from Advance Adapters
http://www.advanceadapters.com/produ...ransfer-cases/
Has anyone been able to get this thing to bolt on without modification? Cutting your tub counts as a mod. I have had to notch one ear of this bracket and cut a chunk out in another place to get it to fit around the shift tower. Now if I want to use 4WD low it looks like I will have to cut the tub as well.
Is there somewhere else I can get a bracket that doesn't need to be modified?
xtrememotives is offline
post #2 of 5 Old 02-02-2013, 12:01 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
I used a Novak shifter on mine.
ratmonkey is offline
post #3 of 5 Old 02-02-2013, 10:13 PM
cj777
1977 CJ7
I used an AA bracket for a little while, but quickly upgraded to the Novak cable shifter. It's a much better solution
Wanna cracker?
'74 CJ5
'81 CJ7
'03 TJ
cj777 is offline
post #4 of 5 Old 02-03-2013, 03:36 PM
Homebrewed2
Home made
I am swapping a nv3550/np231 into my yj behind a diesel. I tucked the transmission and transfer case up as high as i could. I decided to made my own shifter and bracket.
Homebrewed2 is offline
post #5 of 5 Old 04-26-2013, 02:35 PM
Doch80
I just used the AA bracket, cut the body just enough then notched the bracket. I had to make a new tunnel cover but it was easy and looks better then original. Works fine and looks better than stock.
_______
/I ,[_____],
IóL --[]IIIIII[]--
()_) ()_)-o-()_)
Doch80 is offline
