TJ L98 SBC Gearing Suggestions - JeepForum.com
post #1 of 6 Old 04-22-2013, 08:24 PM Thread Starter
95harley
New to this forum...
I have a 1997 TJ project which is 99% done. I am pondering what gear ratio I should go with in the diffs. Currently I have 3.07s but thinking about 4.10s.
Currently the 3.07s handle everything...but think I am losing a lot of bottom end due to the gearing
This Rig is going to be used for street and mild wheeling...
ANY SUGGESTIONS OR IDEAS?
-L98 SBC from 1991 vette (275ish hp)
- AX15 (till it blows up)
- NV231
- Dana 30 - 35
- 6" Long arm lift
- 35" tires
95harley is offline
post #2 of 6 Old 04-22-2013, 10:02 PM
bigorangeyj
the 4.10's would definitely be a lot better, even with the v8. But regearing the dana 35 while running 35's and a v8 is a waste of money in my opinion. 8.8 or dana 44 with 4.10's would be nice. I've found that 4.56's are a nice combination with 35's and street driving.
02BLKTJ-35" MTR/K's, savvy 4", 4.88's, Detroit True Trac 44 rear, Aussie HP 30 front, Big Stereo.
bigorangeyj is offline
post #3 of 6 Old 04-23-2013, 12:57 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the d35 will likely blow well before the ax15, especially with 35's.
8.8's can be easily found with 4.10's and lsd or open. i'd seriously suggest you go that route. even a whooped on dodge 5.2 is more than the d35 can handle, and it's only 235hp at best in good condition.
the chevy motors like to run slightly lower rpm than the dodge and amc equivalents. so 4.10 or 4.56 would probably be good for your 35's. i can't imagine how much driving around on 35's with 3.07's sucks, it was annoying with the 5.2 and 3.73's for me. 5th was practically useless.
ratmonkey is offline
post #4 of 6 Old 04-24-2013, 08:52 AM
yjtyler
I have a sbc with 4.10 gears and 35s, I don't think I would want 4.56 because I have plenty of power in 5th gear to pull a hill
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #5 of 6 Old 04-24-2013, 05:56 PM
rckchucker
I have 4.56's and 37's, had 35's a 5.3 and an AX15. 4.56 is the way to go. Plenty of bottom end and enough speed too without over revving the motor. I turn about 2600 rpm at 75-80 mph
rckchucker is offline
post #6 of 6 Old 04-24-2013, 10:52 PM Thread Starter
95harley
thanks for all the input...Shopping for some new axles to swap in.
95harley is offline
