TJ: hp30, WJ knuckles, new Track Bar - Page 2 - JeepForum.com
 1Likes
post #16 of 83 Old 01-03-2013, 08:17 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Have you decided which pitman arm you will run?
Mail crawling.
MisfitSeven is offline
post #17 of 83 Old 01-03-2013, 09:33 AM Thread Starter
Ben
I liked that you said you fit the TRE above the arm, and something about using the WJ pitman with the WJ knuckles just seems to make sense. So I'm going to start there.
So I need to get that before I set the bracket location.
And I need to get some UPS deliveries before any of that can happen. Looks like ruff stuff & JKS will arrive monday. So I'll have the weekend to work and nothing to do.
Ben is offline
post #18 of 83 Old 01-03-2013, 10:09 AM
MisfitSeven
MAiL Crawler.
I think I was able to pull off the TRE on top of the WJ pitman arm because of my body lift. Make sure it clears when turning.
Mail crawling.
post #19 of 83 Old 01-05-2013, 01:15 PM Thread Starter
Ben
Well I swore I wouldn't do it again, but I pulled a junkyard steering box. Hit shortys this morning, got one from a 98 Durango.
Also got some pitman arms. Wagoneer, WJ, and a chevy 1500 van. I like the WJ still. Need to ream it yet, but I notched the inside so it slips onto the box. The Van pitman would be good, but I don't think it has the length I need.
All in all, good morning at the yard.
chevy van
TJ
WJ
Wagoneer
Ben is offline
post #20 of 83 Old 01-05-2013, 01:41 PM
MisfitSeven
MAiL Crawler.
SJ pitman arms are tapered for Chevy wanton TREs...
What I did was drilled the WJ arm to 3/4" then fit a GoFerIt Offroad tie rod flip insert in it to have the TRE on top.
Mail crawling.
post #21 of 83 Old 01-08-2013, 01:56 PM
GMBNT42
OK, we need to add some info here. How much lift are you using? Assuming adjustable CA's etc? Shocks, fender setup etc? BL? WHat is trying to be accomplished exactly? Sorry late to the party, but subscribed now because I think we are running down the same path. I am currently not lifted, but have a HP Dana 30 too, and started ordering parts for my lift. I want to use no or very minimal bumpstopping, regardless of how much I lift in the end(It will be in the 2-4" range on Long arms).
GMBNT42 is offline
post #22 of 83 Old 01-08-2013, 02:22 PM Thread Starter
Ben
"what do you mean we kemosabe" haha...
Planning on 2" of suspension lift, currently have 1.5" of body lift.
Adjustable short arms, using mainly parts I have laying around.
It will have shocks when I get to them. I'm hoping to have about 10" of travel, with 5" in each direction. Those are very rough numbers, I have a lot to figure out before I figure that out.
Good question. I'll let you know when I figure that out too...
I'm trying to stay within PA state bumper height laws, so I don't want to jack it up, but I want to have travel, so I don't want to add a ton of bumpstopping, like is the common track bar solution. I'm also trying to get bigger brakes, and higher crossover steering.
I'm familiar with suspensions, not with suspension design. I've bolted on a lot of lift kits on Cherokees in the past 5 years, so I've seen what the common pre-packaged solutions for unibodys are.
I now have a TJ that I didn't pay much for, ideally when I'm "done" it should be able to legally make the 2 hour drive to Rausch Creek, be able to hang all day on black trails, then not need a trailer to get home.
Ben is offline
post #23 of 83 Old 01-08-2013, 03:08 PM
GMBNT42
THe problem with High steer applications though is that you run into swaybar link issues on the passenger side though don't you? I thought about doing some type of hi steer application, but it just wouldn't work with the aftermarket swayloc kit I run. Plus with hi steer applications with a low lift height your going to be running serious bumpstopping aren't you?
Again it seems like your goals and my goals are identical. I also only want to run a 2-4" lift and do so with no or very minimal bumpstopping. Want to maximize uptravel. THe only differences I see in yoursetup is going with SA's, I am going to go with a LA kit so I can get the lower control arm mounts on the axle to be flush with the axle tubes instead of hanging below them.
GMBNT42 is offline
post #24 of 83 Old 01-08-2013, 06:24 PM Thread Starter
Ben
I can't really answer that.
Yet...
This is about the distance that it will need to be stopped.
There's a lot that needs to fit in the same spot.
This picture is looking straight down where the TB will be, any more uptravel the bar would hit frame. I need to get some PVC or conduit or something to mock things up with. The frame side bracket is just tacked, I think it can move forward yet.
Sorry the pictures suck. These aren't stock coil buckets. They're centered & tight to the tube.
The IRO gusset is just tacked on. I'm thinking I can use it to mount a heim to.
Similiar to where pcoplin landed his track bar.
http://www.jeepforum.com/forum/f9/3-...l#post11455989
man that bracket is "new" metal and it looks decades old from rust haha.
I don't think that arm length has much to do with axle end LCA mount placement. If you move the axle end LCA mount up, I would think you'd want to move the axle end UCA up the same amount. Or something.
I just added 1/4" LCA brackets to the 30, in pretty much the same spot.
Ben is offline
post #25 of 83 Old 01-08-2013, 06:43 PM
GMBNT42
Yet...
With a long arm kit, the lower axle control arm mounts will shift up behind the axle tube. The upper axle control arm mount will move a tad higher too, but not as much. With long arms the total separation isn't as critical, as I still have enough separation, and the frame side links are within proper proportion still. THey can be a bit closer together with no ill effects.
GMBNT42 is offline
post #26 of 83 Old 01-10-2013, 09:59 AM Thread Starter
Ben
What TRE do you have on top of the pitman. ES2027L? They're huge.
I ordered a ES2234R at NAPA today...
Also. I made a PVC track bar last night. The IRO knuckle gusset doesn't sit proud enough of the inner C for the track bar to clear the coil spring. So I need to space it out a bit further than that. I can go double shear and mount it sideways (so the bolt sits vertical) but that seems like it would be counter productive to travel...
Or I can space it off the knuckle, but that will likely end up single shear. But would seem to travel better.
Ben is offline
post #27 of 83 Old 01-10-2013, 10:15 AM
MisfitSeven
MAiL Crawler.
I run either ES140R or ES62L on top of my pitman. They are stock CJ TREs. Part of Rusty's steering.
Mail crawling.
post #28 of 83 Old 01-10-2013, 11:21 AM
rchase559
Do you have any pictures of your steering?
rchase559 is offline
post #29 of 83 Old 01-10-2013, 11:36 AM
MisfitSeven
MAiL Crawler.
This is what I can do for now. I don't have anything current, and nothing of the TRE over the pitman arm. If my Tcase hadn't locked up and taken out my rear ring and pinion, I could get them. This was my old axle. Same steering.
Mail crawling.
post #30 of 83 Old 01-10-2013, 12:05 PM Thread Starter
Ben
heh. Lemme get a mirror out... I scrapped my DJ-5 years ago.
It looks like CJ is the same 20mm thread as the Wagoneer.
I have access to the 7/8"-18 tap...
Hopefully the ES2234R will give me enough travel before binding.
Ben is offline
