TH-350 to NP-241 Adapting issue. HELP - JeepForum.com
post #1 of 7 Old 09-17-2012, 07:32 PM Thread Starter
RubiExpressTJ
1987 YJ Wrangler
Doing a 350/ TH350/ NP241 swap in my YJ. I have the Motor and Trans already in. The TH350 was originally mated to an NP203 transfer case making the output shaft on the trans only 3/4 of an inch beyond the housing, and the incorrect bolt pattern to mate with the NP241. I've already installed the standard length slip yoke eliminator on the 241. My boss is running this same set up in his YJ but has a spacer or adapter correcting the bolt pattern. What I'm not sure about is the length of his trans. output shaft. I need to know if there is a spacer/adapter that I can use with the short output shaft of the transmission to get the transfer all bolted up!? I can't find any answer to this question online and it's beginning to look like the only route is to change out the output shaft on the transmission and I'm not too into that idea considering it's already in the Jeep. Maybe someone on here as made their own adapter and can give me some ideas? In a real pickle here!
- Luke
RubiExpressTJ is offline
post #2 of 7 Old 09-18-2012, 06:18 AM
jason m
Nothing but the facts
jason m's Avatar
Ive had that combo apart in the the past ( TH-350-203 ) and yes its a very short tail on the TH-350, there is no way I see getting a 241 to mate up with factory parts unless you change that tail shaft.
Theres just no enough meet on the end of the tail to make it happen.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is online now
post #3 of 7 Old 09-21-2012, 09:54 PM
ltrail
1984 XJ Cherokee
Novak has an adapter but it's $$$. I was originally planning on th350 but went 700r/241c the combination was cheaper to buy and rebuild than the adapter kit.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #4 of 7 Old 09-21-2012, 10:50 PM
jason m
jason m's Avatar
This, better first gear all factory parts and only about 3"s longer than that 350 trans.
I run one and its a killer combo, very hard to break.
Jason.
post #5 of 7 Old 09-22-2012, 01:01 PM Thread Starter
RubiExpressTJ
1987 YJ Wrangler
Picking up an NV3500 tonight! I prefer a 5 speed anyway. Was only going to use the TH-350 because of how cheap it was. Should of done my homework. Live and Learn
- Luke
post #6 of 7 Old 10-25-2013, 07:07 AM
Johnboy2892
SB350/Th350/np241c
I am currently working on building my own adapter. I took dimensions from my np204 and my np241c adapters and building a new one. Taking the size of np204 and putting the np241c case holes. Hoping this works out!!
Johnboy2892 is offline
post #7 of 7 Old 10-26-2013, 12:24 PM
Powerplay72
1983 CJ7
Jason, I just finished up the same combo you have. I put a '91 700r I rebuilt, to a Level III, behind my 1969, carbureted 350 and could not be happier. Super fast, and smooth shifting... Did I mention OD!
Powerplay72 is offline
Flywheel/ dust plate issue Devil_dog16 YJ Wrangler Technical Forum 1 09-27-2012 09:22 AM
89 YJ 350/700R4 distributer issue rcn11thacr Advanced Jeep Tech 2 09-14-2012 03:47 PM
4L60e shifting issue sirhc76 Advanced Jeep Tech 1 06-05-2012 07:12 AM
