tapered pitman arm sleeve? - JeepForum.com
post #1 of 17 Old 03-03-2012, 09:39 PM Thread Starter
Ripper3494
im wondering if these exist, i cant find them. and where they are sold. the idea is drill out your pitman arm to say 3/4" and weld in a sleeve with the correct taper for your drag link. currently my problem is my drag link is hitting my tierod with the longer wagoneer pitman arm. so for temporary fix id like to use my yj length arm with a hole tapered correctly for the wagoneer steering.
thanks in advance
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #2 of 17 Old 03-03-2012, 10:26 PM Thread Starter
Ripper3494
nothin?
build thread:
RC vs BDS
post #3 of 17 Old 03-03-2012, 10:42 PM
Garza
Since the TRE you are using now fits the Waggy pitman, and is obviously larger than the YJ taper.....I have used a unibit (step bit) and it works good, but you will need to do that in a drill press and just do a very small amount at a time so you don't go too far.
RG
Garza is offline
post #4 of 17 Old 03-03-2012, 10:51 PM
95yj-af
You could get a machine shop to make one for you. Just bring in the tapered item and they could make a sleeve for it. Probably would be faster than ordering something online.
95yj-af is offline
post #5 of 17 Old 03-04-2012, 08:33 AM
jason m
Nothing but the facts
jason m's Avatar
Fill the hole up with weld and redrill/tapper a new hole to your size.
Or drill straight threrw and run a Heim on that end, worked for me for 7 years with no falure.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #6 of 17 Old 03-04-2012, 02:01 PM
mj40
1989 MJ Comanche
found these from teraflex on ebay...just need to match the taper to your needs..
mj40 is offline
post #7 of 17 Old 03-04-2012, 03:07 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The Chevy drag link end tapers are the same angle (7), but the start and finish id's are larger than the tire rod ends.
The snap on reamer has served me well. A step bit is a very bad idea..
ratmonkey is offline
post #8 of 17 Old 03-04-2012, 03:48 PM Thread Starter
Ripper3494
thats exactly what i was looking for
build thread:
RC vs BDS
post #9 of 17 Old 03-04-2012, 04:17 PM
jkl
poly performance has these
http://www.polyperformance.com/shop/...r-p-21283.html
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #10 of 17 Old 03-17-2012, 06:51 PM
Backroads
Ruffstuff specialties has them for chevy 1 ton tapers.
Backroads is offline
post #11 of 17 Old 03-17-2012, 07:40 PM
fratis
fratis's Avatar
this would be the way to do it.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #12 of 17 Old 03-17-2012, 10:23 PM
pcoplin
If the pitman arm is still stock, just buy or borrow a reamer bit (~$80) and ream it out yourself. No need for a sleeve.
Bit you could also make yourself sleeves by reaming out some DOM or 4130 tube and welding that in.
FullStack MotorSports
pcoplin is offline
post #13 of 17 Old 03-29-2012, 11:22 PM
Climbit
I would not run a sleeve without welding it in, and I wouldn't weld one into the pitman arm.
Climbit is offline
post #14 of 17 Old 04-01-2012, 01:24 PM
pcoplin
Why not? Works very well. I have welded inserts on my flipped WJ knuckles. They'll never come out. I'd weld all over a stock pitman arm with no worries. Of course, you'll want to TIG it to limit the spatter...
pcoplin is offline
post #15 of 17 Old 04-01-2012, 03:11 PM
Climbit
aren't the stock pitman arms cast? I would think special welding technique would need to be done to make it strong enough. stock pitman arms are cheap enough, just get one reamed.
Climbit is offline
