Suspension Geometry - Page 15 - JeepForum.com
post #211 of 361 Old 01-11-2013, 08:38 AM
tyvanwie
Alright. I need to get everything and play around with it. I'm more of a visual learner. Do you think this is a good plan so far? I'm open to suggestions. I know I definitely want the 4 link rear.
tyvanwie is offline
post #212 of 361 Old 01-11-2013, 09:00 AM
tyvanwie
Found this yesterday
http://www.4wheeloffroad.com/techart...2/viewall.html
tyvanwie is offline
post #213 of 361 Old 01-11-2013, 09:38 AM
Imped
Imped's Avatar
Eh, that link is OK but you still won't catch anyone that has a good understanding of what's going on doing any of that. Once you understand 'why' you won't need to read anything or open the link calc....there are enough links in this thread already for you to get to that point.
OlllllllO
IndyORV
Imped is online now
post #214 of 361 Old 01-11-2013, 09:44 AM
tyvanwie
Yeah, still working my way though it. I had found that link before I found this thread.
tyvanwie is offline
post #215 of 361 Old 01-11-2013, 10:04 AM
tyvanwie
Originally Posted by MisfitSeven
I would say to get an 8.8 just for the peace of mind.
Since you want a 4 link, don't buy an axle swap kit. All you will need will be a truss, spring pads, shock mounts or tabs, UCA tabs for on top of the truss, and 10* LCA brackets. You can piece together a kit for cheaper than a swap kit. Put your 8.8 in at the same time you do your rear suspension.
http://artecindustries.com/TJ-88-Swa...uss_p_233.html is this what you were referring to?
tyvanwie is offline
post #216 of 361 Old 01-11-2013, 10:32 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
The Artec kit is nice, no question. But you can piece together a kit for cheaper yourself. Check out RuffStuff.com. They sell everything you could need. Their trusses are a bit tall, especially if you want to stay low.
Mail crawling.
MisfitSeven is offline
post #217 of 361 Old 01-11-2013, 10:41 AM
tyvanwie
Artecs are a bit tall?
tyvanwie is offline
post #218 of 361 Old 01-11-2013, 10:44 AM
Imped
Imped's Avatar
No, Ruffstuff......just compare them.
Personally, I really like small, simple trusses that tie into the diff cover.
And there was a pretty good truss discussion back on page 3: http://www.jeepforum.com/forum/f369/...57/index3.html
OlllllllO
IndyORV
Imped is online now
post #219 of 361 Old 01-11-2013, 10:56 AM
tyvanwie
Thanks guys. This is all still new to me. After work i will be sure to read this whole thing
tyvanwie is offline
post #220 of 361 Old 01-13-2013, 01:11 AM
Ripper3494
i think ive finally designed something that will fit under my jeep. whats your thoughts?
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #221 of 361 Old 01-15-2013, 05:30 PM
Imped
Imped's Avatar
A new picture I thought was pretty cool
OlllllllO
IndyORV
Imped is online now
post #222 of 361 Old 01-16-2013, 12:08 AM
Climbit
slightly off topic
the problem with those is they don't really do much to stiffen the axle at all.
really they aren't much more than a link bridge.
if you are going to build a truss, run it out as far as you can get it. that's one thing that is awesome about the artec ones. they get you plenty of strength out that far without adding too much weight.
Climbit is online now
post #223 of 361 Old 01-16-2013, 07:13 AM
Imped
Imped's Avatar
Originally Posted by Climbit View Post
slightly off topic
Right, but they're very easy to build off of. I'll be doing that when spring arrives.
OlllllllO
IndyORV
Imped is online now
post #224 of 361 Old 01-16-2013, 05:02 PM Thread Starter
cycleguy04
Well, I know you have a reason for every aspect of your four link build. Why are your upper joints at the axle so far apart?
'98 Wrangler Sahara - SOLD
'91 Ranger XLT 2WD - 4.0 V6, A4"hell"D, contemplating twin turbo 5.3
'79 C10 Big Ten 2WD - 350, TH350, contemplating rebuilding to 355ci with supercharger and programmable EFI
'12 Subaru Forester (AKA: Arctic Cat) - 2.5, non-CVT, wife's, still begging her to let me get an exhaust system
'01 SV650 - snorkelectomy, ebay slip-on, cam swap and re-jet in the near future
cycleguy04 is offline
post #225 of 361 Old 01-16-2013, 10:14 PM
Imped
Imped's Avatar
Remember, my arms are shorter than most you see so they'll converge at the axle further apart. The Poly mounts sit at ~27 degrees in so I put the axle mounts where they needed to be in order to be inline with the frame mounts. When originally setting up the axle mounts on the truss, my axle was still 6" further forward than where it is now. I took a future stretch into account and put them a bit further inward and they line up perfectly where the axle sits now.
OlllllllO
IndyORV
Imped is online now
