Suck down winch - JeepForum.com
post #1 of 14 Old 04-17-2012, 08:57 AM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Suck down winch
I am wondering if I could run a fnr suck down winch in place of limiter straps? Also have found they are good for climbing, but what are the other uses for suck down winches?
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #2 of 14 Old 04-17-2012, 09:35 AM
Ripper3494
I would deff not use a suckdown winch to replace limiting straps. But other uses are to fit under stuff easier, hill climbs...and thats about it. I think theyre overrated and if you have your suspension set up right you wont need a suckdown winch for hillclimbs anyway
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3 of 14 Old 04-17-2012, 11:02 AM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Why would they not work as limiters? My thinking is that they would be a teeter that once one side hits the bumpstop the other wouldn't be able to droop any further, or wouldn't that work?
post #4 of 14 Old 04-17-2012, 11:13 AM
Hussler
1992 XJ Cherokee
Because the winch is centered I don't think it will have much affect on articulation.
You would have to cut down the wire to the point where it is no longer spooled at full droop, which means you are relying on very little holding that cable to the winch IE the little retaining bolt.
Now if you wanted to install a winch for each wheel that would be interesting LOL
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #5 of 14 Old 04-17-2012, 11:19 AM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
My problem is trying to fit 4 limiters on my narrow axle rig with 18 in coilovers. I was thinking of running a 2 in strap spooled on the winch instead of cable, but I could also have a safety chain or something that never lets either side go too far?
post #6 of 14 Old 04-17-2012, 02:16 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Plus if you ever have to use your winch for winching, then you have nothing limiting your axles.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #7 of 14 Old 04-17-2012, 02:25 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
I'd buy a front and rear suck down dedicated winches, and still keep my receiver mounted winch for pulling.
post #8 of 14 Old 04-17-2012, 02:28 PM
Hussler
1992 XJ Cherokee
There should be a **** ton of spots you can mount regular straps too, people mount them on their radius arms, axle truss, axle control arm bolts ect. As long as they are away from any moving parts and are not far off the traveling path of the suspension on one side of the vehicle.
Separate winch from your tow winch, they are usually small >1000lbs winches mounted beneath the jeep or just above the floor on the inside. One time I saw one that had a pulley rigged through the floor in the front with the pulley bolted to the engine
Hussler is offline
post #9 of 14 Old 04-17-2012, 02:34 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Barely made room for the coilovers. Would they be strong enough on the arms. Tom woods wants one on the pinion as well. Wouldn't a good center one fix it all?
image-915819996.jpg   image-721612945.jpg   image-2221933496.jpg   image-4232993637.jpg
post #10 of 14 Old 04-17-2012, 04:09 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Just bought 5 30in limit straps because they where $7 a piece at fleet farm. Also picked up a 3000lb super winch for $120. What should my plan be? Suck down, limiters, or both.
post #11 of 14 Old 04-17-2012, 06:42 PM
Hussler
1992 XJ Cherokee
Well I believe the center of the axle pretty much stays on the same plane when articulating horizontally (not uphill or downhill) so it wouldn't actually limit anything (unless your problem is the unloading of the front or rear suspension up or down a hill)
Are you going to run two uppers? Thats quite the big setup for one upper, not good for mr. pinion angle with some torque applied.
Hussler is offline
post #12 of 14 Old 04-17-2012, 07:25 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
If its a bad idea I'm fine with that. Im just visualizing a teeter totter off the cable in the center, once one side hits a bump stop the other side can't droop anymore. Right now it seems to me the easiest route would be a limit strap in the center stopping droop off the bumpstop, then have the suck down winch for a suck down winch. I also don't see why it wouldn't work in the rear, but my rear is simple to limit strap as there is tons of room, and I don't see a need to suck it down.
post #13 of 14 Old 04-17-2012, 09:10 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Full droop, ride height, full squat. Not as bad as I was imagining.
post #14 of 14 Old 04-17-2012, 09:15 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
This is how I'm envisioning said limiter.
